Results 1 to 7 of 7
Thread: Help!
    Jan 2023
    6
    Help!
    I NEED A LOT OF HELP WITH TUNING MY 2012 CAMARO LS3 WITH MANUAL TRANMSSION.
    The only modification I have done to it is installed a cam. Everything is stock (except the air intake and the exhaust is straight piped for now)
    The cam specs at .050 is
    Intake - 230 deg Exhaust- 242 deg
    Any help/coaching is appreciated.
    I am currently having issues starting it up. it wont start unless i press down on the gas a little.
    1,615
    Post tune and log
    Jan 2023
    6
    Heres the datalog and the global file
    camaro ss datalog.hplCamaro vats delete.hpt
    @gtstorey
    Apr 2022
    Ohio
    3
    Try this. Raised your RPM and idle air plus bumped up timing in idle areas. Should help you get started
    Jan 2023
    6
    Thank you that helped a lot. Do you know how to tune the fuel flow?
    Apr 2022
    Ohio
    3
    Search for threads on VVE tuning from Cringer and Smokeshow. They both have detailed threads explaing how they do it. They go into full depth explaing on how to set up the scanner and what all to log. GHuggins is also another one to look at for advice on tuning the VVE tables. Im no expert so I would look at post by them or even message them for help. They all seem like stand up guys and I am sure they will help or point you in what direction to go.
    Cringer also has some Youtube videos on it and even has some programs that make it a lot easier.
    Mar 2009
    Andover, MN
    538
    There is a search function on the forum.
