Results 1 to 13 of 13
Thread: GM 5.3 3RD GEN cam swap and headears bog on WOT
    Oct 2023
    39
    5.3/th350
    At.50inch lift222int/232exh 112+5 .550/.550 CAM
    long tube headers
    walbro fuel pump 255LPH
    Hopefully someone can help me out, im new to tuning
    i ls swapped a my nova with just cam and headers
    idles fine i guess but the timing jumps around
    but the main thing is when i go to hit WOT it wants to bog down and pop likes it not getting the fuel
    THANKS IN ADVANCED
    g3 ls p4.hptLS 5.3 CAM SWAP HEADERS DATA.hpl
    Oct 2023
    39
    could be my injectors idk the inj duty looks a little wonky at times
    running stock injectors by the way
    Dec 2019
    MS
    1,251
    I dont see a wideband input in the datalog.
    And timing is in the single digits so its going to feel really weak.
    Have you checked your fuel pressure?
    Oct 2023
    39
    yeh im going to get a wideband today my other broke
    14,066
    Needs more injector too, for sure because you are going to go higher than 6,000rpm with this camshaft.
    Stop flooring it if it's untuned like that, you're going to hurt something. You need to redo the whole airflow model before you start worrying about how it bogs when you floor it.
    Double check your fuel pressure too.
    I can't edit your tune as I use the older MPVI but you still need to setup the tune for the camshaft. The idle and timing settings need more changes, abuse mode on the engine side needs changed, set to 7,000rpm and 0mph. In the systems tab, systems options the brake torq mngt needs to be set to zero.
    Sep 2021
    Kentucky
    1,848
    You can try this, im sure its a better start than you had.
    Oct 2023
    39
    alright thanks definitely going to try with the timing and airflow
    Oct 2023
    39
    alright ima try it tommorow
    5BA8
    5,470
    First thing you need to do is put a fuel pressure gauge on it. Preferably one you can see while driving. No tuning adjustments should be made without first confirming you have adequate fuel pressure at all times, not just idle.
    email=[email protected]
    Oct 2023
    39
    yeh im going to get one
    i checked idle its at 70psi which is hella high
    but i dont know driving
    im running a cheap amazon corvette filter which is supposed to be 58psi
    Oct 2023
    39
    Yeh it?s hell of a lot better
    Dec 2019
    MS
    1,251
    Quote Originally Posted by LuhReik View Post
    The factory C5 vette filter/regualtor is suppose to be 58psi with the factory pump.
    Im pretty sure you can see your problem above in red.
    Get a wix filter and try again.
    Ive thrown away so many of the cheap filter/regualtors i cringe when somebody brings me something to be tuned with one of them dang things on there.
    May 2025
    I need my 99 5.3 lm7 has ss2 cam btw rockers and lifters had it tuned with hptuner and it dont like to take throttle it just bogs
