Sorry I got swamped this morning and just now was able to get to this. So here's a screenshot showing the bind with your previous tune. Now I have some math channels setup in there to calculates the precise ratios and the actual line pressure achieve in the unit so you won't see the same on your end if you graph the data so it would not be as obvious for you. You can see the bind when the yellow ratio graph line drops down to 1.472 then climbs back up and finally settle down to 1.53 like it should for third gear. I have put in read circles the points where you can see what is wrong and causing it. Bind 2-3.png
Next here's a screenshot of the 2-3 under almost the identical conditions after you modified your tune adn now you can see a nice gradual shift without a drop down in ratio below the 1.53 like it should for third gear. This time I put green circles around the same points where things are now commanded properly to achieve a nice clean 2-3 shift. Nice Shift 2-3.png
Hopefully this helps clarify things,
