Page 2 of 2 FirstFirst 12
Results 21 to 24 of 24
Thread: Perameter Selector not working HELP!
    I am fairly confident that I have been doing it correctly for the past 4+ years. But if doing what you suggested works I will be the first to admit it. Will let you know.
    5BA8
    5,480
    Screen shots of what you're seeing would help greatly. It says "HPtuners tech support" in my sig for a reason. I did trackside tech support for them for several years. It's not just something I'm randomly claiming.
    If you opened a tech support ticket you need to include an info log and dat.debug file. You can find that under Documents/HPtuners/Settings.
    When collecting and saving your info log you need to be connected to the car with the ignition on, engine off.
    email=[email protected]
    So I have fixed this issue. One thing edcmat-l1 highlighted with his last comment was that I had l had deleted the software and re installed it but I had not deleted its sub folder. This sub folder is what contained the issue whatever it was. So I uninstalled the software and deleted the folder. Then I re installed the software that populated a new sub folder. I opened one of my logs and I can now use the parameter selector as per normal. Thankyou for your help highlighting the issue edcmat-l1
    5BA8
    5,480
    Quote Originally Posted by Bullet300 View Post
    You're welcome. Just for the record, you don't have to do an uninstall/reinstall. Just empty the vehicles folder. Glad you got it fixed.
