Results 1 to 7 of 7
Thread: Tuned for 14.7 AFR but goes to 14 when I unplug MVPI?
    Maybe is just a coincidence? I am running 1 Bar RTOS tuned Speed Density. When I finished up my fuel adjustments I reenabled closed loop. I left the WB O2 hooked up so I could monitor things. I noticed for some odd reason truck is now running high 13's to 14:1 AFR. I think is odd so I plugged the laptop back in and it started 14.7:1 AFR. I cannot figure out what's up. It seems when I try to log it w/ MVPI hooked up, it goes back to 14.7:1 AFR so I cannot catch it in a log file to trouble shoot. I'm a bit baffled. Any ideas?
    13 2023-11-11 263109 PE tuned, RTT OS, MAF DISABLED.hpt
    15 LOG D.hpl
    Mar 2021
    Pompano Beach FL
    271
    You are logging commanded A/F not actual . Also A/F will always swing some at idle or part throttle
    www.n2speed.com
    http://www.amp4x4.com
    [email protected]
    Dodge And GM Tuning Suppport
    Diablosport CMR | HP Tuners
    No, I am using a wideband. It was tuned with a wideband and I am logging with a wideband. STFT are giving me 14 AFR instead of 14.7 AFR when I unplug the MVPI and I cannot figure out why. I plug back in MVPI and it shoots up to 14.7 AFR
    1,558
    Quote Originally Posted by weinerschizel View Post
    So you are saying the afr gauge is reading different? I would expect the gauge or wiring being the problem causing a voltage issue.
    Aug 2016
    Swansea Wales UK
    186
    Are you earthing the wideband om the same point as the narrow bands
    Gen3 L59/4L60E LS3 cast manifolds, Small Cam change, 2800 Convertor, MPVI, using MTX-L for wideband tuning
    Interesting question... I grounded it to the accessory power. I could check PCM ground to accessory power and see if there is a load there.
    I bet when the MVPI & Laptop are plugged in it's tieing the grounds together with the accessory / WB and the PCM through the OBDII port. Genious, I'd have not thought of that.
    I tuned to 14.7 at cruise... and 12.2 at PE
    When I unplug the computer PCM goes down by about 1 AFR.
