Thread: 6.0 turbo whistle
    Oct 2023
    3
    6.0 turbo whistle
    05 6.0 with kc 10 blade and 4? exhaust. what?s settings can i change to get the most whistle at idle and settings while cruising?
    Advanced Tuner projectlnf's Avatar
    Jun 2012
    warrenton va
    490
    What strategy are you on?
    If your on a non inferred strategy you won?t be able to do it as well.
    In you EBP tables down at idle around 0-22mg and from 0-700 or 800rpms. Jack up your pressure to 200kpa
    That should get your vanes to close at idle.
    Oct 2023
    3
    Vxcf9ca
    Jun 2012
    warrenton va
    490
    Not mistaken your on a non inferred Strat.
    Try to do what I described up above and see how that works. Either way that is the way I make the whistle in my tunes whether it is inferred or non inferred
