Originally Posted by
NobleTech
That's what I would think too, however, I looked at the tables, and I am lowering the values, as you can see in the tune files, and then I make a run or just driving on the dyno at part throttle and the correction factors go the other direction, in other words histogram says negative -10 to -12, so I go take that much fuel out of both of the maf and the VE tables, I do another log and now it says 20 to 24% negative
I'm quite sure both of the tables values are going down, but it's adding fuel, I have two wide bands, one is in the exhaust and hooked to the scanner, the other is on the dyno and they both read the same air fuel ratio, so I confirm that I'm not getting garbage data from my wide band
It's almost as if there is another table like a secondary VE table that I cannot see in the tune, but is looking up that table when I go into PE mode
