What are you doing bro. Nice panic posts that link makes absolutely no sense its just you pretending to respond with no explanation for why you didn't know you need to use analog offset to correct a wideband input as per the 2007 instructions laid out previously on this forum. Its right there in front of you.
https://forum.hptuners.com/showthrea...ll=1#post79124 You are in a panic now because your mentor has been using widebands wrong for 17 years apparently. You obviously didn't know about the correct math formula:
This is all that it comes down to. Why didn't you use the correct formula.
Why didn't you make a analog offset term. Because you didn't know it exists. You need to confess about using the wrong formula and teaching the wrong formula. For 17 years apparently.
Its already there. If you admit it now you can at least say you are honest.
