Anybody have a base tune for the ls3 with texas speed shop stage 3 camshaft? Runs but wants to die out at idle.
Tim
Tim
post your tune so we can help you
here is the tune thats in vehicle
Charppv.hpt
Probably best to post in the gen 4 section, but try adding 4 or 5 g/s airflow to the idle area down to 0 rpms of your min airflow table then smooth it up to 4000rpms from there. It should crank and run then so you can dial in the air models and the rest necessary to get it running right.
~Greg Huggins~
^Agree...Likely needs more running airflow at idle.
