Results 1 to 10 of 10
Thread: 2019 challenger rt brand new ulocked pcm
    I hope i havent made a mistake spending like 1k on this pcm.
    1. all i want to do is disable bank 2 02 sensors. because i installed 6.4 headers and cats and it is throwing a code
    2. I want to disable MDS i have no place under fuel to disable it
    3. i want my active exhaust open all the time.
    I am a complete noob to this.i watched a lot of videos and looked in the forums. i am sick of searching i just want to know how to do it. thank you for any help
    Jan 2022
    975
    email me your tune
    [email protected]
    don tanklage
    tune
    tune has been emailed thank you
    Dec 2023
    weatherford texas
    9
    Are you using the beta?
    I have tried both.
    I am hearing that do to EPA. They have disabled the right to disable the CEL and MIL lights? Which is one reason I bought it. I wish I had known that, along with MDS disable and open the Active exhaust.
    The only way I know how to disable The CEL lights is to use an older version of HP. Tuners
    2019 challenger rt
    k&N cold air intake
    92mm hellcat throttlebody
    ported 392 intake manifold
    ported eagle heads
    Cammotion custom 222/234 cam
    stainless works long tube headers and catless mid pipes
    3' catback with h-pipe & pypes violator mufflers
    e-85 tuned
    3.70 lsd
    5BA8
    3,640
    Quote Originally Posted by james1595 View Post
    Or go through the "EPA compliance" training.
    email=[email protected]
    Aug 2021
    Akron, OH
    34
    If you go under Help then parameter access under the VCM editor it will take you to a test then let you disable certain emissions related parameters. If you live in an emissions testing state you will most likely fail the inspection. The CEL won't be on but also the monitor will say incomplete. Where I'm at in Ohio all or most monitors have to be completed and no codes depending on the age of the vehicle.
    I took the test. Thankyou for the info.
