Having an issue with a friends car he has just purchased . Engine is 416 ls3 with 1900 lsa supercharger 6 speed automatic . Vehicle not running right and advised maybe best starting from scratch on tune but he was able to get use of a friends dyno for a couple of hours so i thought we would have a bit of a play. Vehicle had the PE at 1.00 has tuned the whole fuel map this way , so i advise would be good to get it running on a PE table as would be easier to transfer info into tune . Anyway started doing this with reduced timing and for some reason will not make power on PE tune and goes into knock if try to put timing into it
timing scale adjustment.hptvf supercharged wagon.hptold 01.hpl10.hpl
