Results 1 to 9 of 9
Thread: 6.7 pats and other systems
    Jan 2024
    3
    Can HP tuners disable PATS and other modules? I?m wanting to swap a 6.7 and 6R140 into another vehicle, but I know I?ll run into issues with PATS and other canbus issues. Short of a motec standalone, can I flash these out with HP Tuners?
    Aug 2023
    canada
    51
    might yea but you might have to use either forscan or ids to disable other modules.
    Aug 2023
    Nevada
    31
    Are you swapping it into another 6.7 truck?
    Jan 2024
    3
    No, totally different platform
    Dec 2023
    8
    Done a 2013 F550 drivetrain swap into a 79 F600...using ForScan only...kept all the Emissions in place...Calif CARB legal swap
    Aug 2023
    Nevada
    31
    Quote Originally Posted by jshelk View Post
    PATS is a BCM thing. I haven't seen anything related to pats displayed by hpt in the ecm. Might need IDS.
    Jan 2024
    3
    Quote Originally Posted by Taco Stand View Post
    Oh that?s exactly what I?m looking for! Did you figure it out on your own? The ForScan spreadsheet doesn?t seem to be enough.
    Dec 2023
    8
    Figured out the process doing an Excursion/Raptor Drivetrain Swap.... then it became rinse and repeat on any FORD
    We just reference Ford's PC/ED Manual's and work the Faults Codes Module by Module.
    Short version: having access to FJDSS is/was helpful ...but with Forscan Hack what you can and build "simulator plugs" where you cant...
    https://www.motorcraftservice.com/Purchase/ViewProduct
    Sometimes in the BCM in particular depending on how much logic/ controls your bringing to the host vehicle it's almost always easier to reflash and regress to XL trim parameters...
    Jan 2024
    Ended up emailing the stock read to the tuner. Mine is a 2006
