If someone took a stock ecm file from the readout and saved it properly and performed the sotf patch properly. are you able to open up that new sotf file and beable to see the different switch positions and tables ? or does it need to be flashed into the ecm first then read back out for those other tables to appear ? or are the sotf tables all part of the user defined parameters ?
