URD 61lb injectors
Have any of you guys used the 61lb injectors from URD on the Tacoma's? I have a 13 I'm working on and I cant find any data whatsoever. I already maxed out the inverse on the injector scale and the truck just dumps fuel in. I'll continue to work on it see if I can figure something out.
I have data for these injectors.
What values are you using?
Following. And also interested in a trd tune file if anyone has one.
Sorry for no update. turns out the o2s were bad. and the engine had a broken piston. its back up and running now. I'm running a value of 7.335 for the constant and 2.85 for the inverse. using the maf airflow curve from a stock supercharger tune as well.
fuel trims show -20 still but the wideband gauge pegs 18+ afr. so idk which to believe. the o2s are brand new too.fresh build.hpl
