Results 1 to 13 of 13
Thread: Closed loop issue's
    Closed loop issue's
    So after some looking around Ive seen some limited folk with some of the same problem im running in to.
    Quick run down on what i've got.
    86 c10 5.3 swap with 4l60
    Medium cam 600ish lift 112 lsa bla bla bla
    Amazon's finest sheet metal intake money can buy!!
    Longtube's to x-pipe with some spintech 3000 series mufflers
    Speedmaster dbc standalone harness
    00 Silverado dbc pcm
    ls3 injectors
    2200 stall converter i think??
    Maybe a few other lil small things but ya get the picture.. Mild build.
    Problem is 02's are not sampling. They hang at 450ish mv with very little movement. 3-5 mv. Pcm will not go in
    closed loop. Keep getting fuel system ol fault. I have ohm'd the loom from pcm to o2's with success. Both high and low
    signal's are checking out. Heater circuit is fine along with the common ground. Was hoping someone-someone's have
    had this issue and can point me to the fix!!
    Aug 2009
    Calibrating
    3,378
    Means you have bad 02s or wiring to 02s is messed up… see this all the time
    15 C7 A8 H/C 2.3 Blower/PI
    14 Gen 5 Viper
    o2's have been replaced with new denso's then new ntk's. I continuity/ohm tested all o2 wires between pcm and o2 sensors. High/low reference, heater circuit, and ground. All check out. ???
    405
    2,364
    What wiring harness? Name brand aftermarket or self modified OEM?
    Speedmaster aftermarket... Yet it most likely is just a cheap china harness reboxed. I own several of those china units and have had hit or miss results.
    So i tried a "name brand ish" harness to see the quality differences and im not impressed.
    Tuning Addict
    6,876
    Mitch at swaptime does some of the best harnesses I've seen and if something is wrong he'll usually help walk you through diag and fix it. As of late he's even started using a lot of the OE wiring colors.
    I would recommend finding a schematic for what the ecm is programmed to then back tracking pins for powers and grounds along with the correct signal voltages.
    ~Greg Huggins~
    Quote Originally Posted by InandOutPerfromance View Post
    Continuity test to the PCM is meaningless if the wire harness is pinned wrong at the computer. This is extremely common.
    405
    2,364
    Can't go wrong with PSI harnesses. What O2 are you using. You said 00 Silverado PCM. There were 2 styles used that year. Do yours have flat 4 pin connectors or square 4 pin connectors?
    Aftermarket harness from speedmaster. Harness has male square o2 plugs.
    When i was testing i was testing harness. I looked up pinout for a 00 silverado and from what i can find the high/low signal are 26/29 and 66/69 and those match the harness i have.
    5BA8
    3,524
    The 450mv O2 scanner reading is an open circuit default value. It is most likely wired incorrectly. Especially if it's the same with multiple replacement sensors.
    email=[email protected]
    Nov 2023
    28
    ls3 injectors
    yes i had that problem myself and found out they sold me sensor 2 instead of sensor one and my mv stayed at 450 like yours and would not go into closed loop make sure you have sensors 1 installed air/fuel sensors sensors 2 will not work there only for catylst eff.
    2,922
    There is also something about grounded and non grounded o2 sensors. I don't know for sure but blindsquirrel has talked about it.
    Tuner at PCMofnc.com
