Not real sure if I'm posting this in the correct forum but..as the title says,im trying to wire an electric cooling fan into the stock pcm of my 2000 s10 2.2L with the L4big pcm..the truck came stock with a clutch fan but I want to switch it to an electric cooling fan controlled by the pcm so I need to know what pin of the pcm is fan 1 ground signal for the electric fan relay..ive googled it a bit and found someone saying its pin 54 of the black pcm connector on a 98 cavalier but could not confirm or even find out if the cavalier pcm has the same pcm connectors..anybody have the pcm pinouts for the L4big pcm (00' s10 2.2L)? or does anybody know if the cavalier is indeed the same pcm/connectors etc and if so, anybody got the pcm pinouts for a 2.2L L4big pcm cavalier (id assume a 2000 as well)?? any help would be appreciated,thanks in advance
