Results 1 to 3 of 3
Thread: Help with quicker shift points
    Jan 2024
    the moon
    5
    can anyone explain to me these tables under the shift timing tab, what do i do if i want quicker shift points?
    13,610
    Only edit the base table. And pretty much the only thing being used will be the X pattern.
    The values in the table are time. So .3 seconds or .4 seconds for example. If you want to quicken them some you can set them to .275 to .300 and be pretty safe. Adding a little line pressure can help too.
    Also on the 4L60/70's you can install the corvette servo to help with shifting.
    Jan 2024
    the moon
    5
    I'll give that a try, thanks for the help. whats the point of the torque adder table for?
