Page 6 of 8 FirstFirst ... 2345678 LastLast
Results 101 to 120 of 155
Thread: New Fuel Pump VE Try 2
  1. #101
    Apr 2022
    217
    Well hopefully theres some change for the good lol. little tip in kspark retard on warmup maybe normal
    50lb sd warmup 1.hpl
    50ln sd 1.hpl
  2. #102
    Mar 2022
    Indiana
    3,056
    Ok log this one with more varied driving like you did with MAF.
  3. #103
    Apr 2022
    217
    tried to get into the throttle hard on back roads lol. also i fixed my wideband offset as it was reading .7 below on the logs than what it showed on guage.
    50 lb sd 2.hpl
  4. #104
    Mar 2022
    Indiana
    3,056
    It was? What is your formula then?
  5. #105
    Apr 2022
    217
    *2.3750+9.8125
  6. #106
    Apr 2022
    217
    Been trying to fine tune it but it’s jumps around so much try to get it averaged out. on the maf runs like it was 14.7 around there pretty much untill PE and in cold of course
  7. #107
    Mar 2022
    Indiana
    3,056
    That's the formula I've been using, too. Narrowbands confirm that.
  8. #108
    Apr 2022
    217
    Oh ok, so it’s different on your end than what I have been seeing? So when I log your able to change the maths around just not add Pids J haven’t added right?
  9. #109
    Mar 2022
    Indiana
    3,056
    What's your idle fuel pressure? It should be around 50.5psi.
  10. #110
    Mar 2022
    Indiana
    3,056
    Quote Originally Posted by Lxjoshxl View Post
    Yes, you can make whatever math you want. The raw EGR voltage is what I get from your log.
  11. #111
    Apr 2022
    217
    Yes it’s around 50.5 at idle. Wot 60ish maybe little off. Why do I read it should be around 54 maybe stock setups
  12. #112
    Mar 2022
    Indiana
    3,056
    Alright just trying to figure out why VE is so high. Thought maybe the pressure was regulated low. The other thing would be displacement. A lot of ATK engines are overbored, but nobody is boring out an LQ4 to 6.8L.
  13. #113
    Apr 2022
    217
    Yeah it is 30 over I’ll double check base psi in morning but pretty sure it’s still 58. Which makes me still wonder if something internal could cause a High VE table
  14. #114
    Mar 2022
    Indiana
    3,056
    Nothing internal is going to make it breathe that well. Thing is it's not that efficient at all. Low fuel pressure, incorrect injector data for the injectors, displacement, or high ethanol content can throw this off.
    It's no big deal I can correct the timing. Just pointing out that you should verify fuel pressure. 58psi is with vacuum line disconnected or at WOT.
  15. #115
    Apr 2022
    217
    Yeah we’ll I did notice VE was still lean was hoping to see it go way rich like mentioned. I wonder if this aeromotive regulator is just not good it’s the second one I got, it does drop off after primed, but I know it’s a return style so that’s normal. Maybe Engine shop fucked timing up could that cause inflated Ve?
  16. #116
    Mar 2022
    Indiana
    3,056
    No I don't think the machine shop did anything wrong in that regard. As far as aluminum in your oil then maybe, but nothing to do with VE.
  17. #117
    Mar 2022
    Indiana
    3,056
    Try to keep an eye on pressure during WOT.
  18. #118
    Apr 2022
    217
    Ok, I wish I could log this gauge, lot of times been busy watching knock and wideband to see if I’m safe
  19. #119
    Apr 2022
    217
    fuel pressure is holding. i know the regulator when keys off doesn't hold pressure because its a return style.
    50lb sd 3.hpl
  20. #120
    Mar 2022
    Indiana
    3,056
    You checking whether pressure holds when it shut off at 5:21 right?
