Thread: stock 4.8 with 78mm turbo
    Mar 2023
    im completely new to tuning and wanted to try to get a base tune for my 2011 4.8 Silverado installed a turbo 78mm vs racing huron kit and im trying to go speed density trying to get it to run right on just a start up for speed density.
    what all do i have to change
    13,606
    What injectors are you going to use and did you buy a 2 or 3 bar MAP sensor for boost yet?
    Mar 2023
    Stock flex fuel injectors for now on a 3lb wastegate spring and stock map is on right now but I do have a oem zr1 map I?m going to be putting on
    Sep 2023
    Bay Area, CA
    44
    if its not solely used for drag racing may want to consider using a maf sensor
