Results 1 to 20 of 22
Thread: 2013 Impala 3.6 LFX - Overkill 87 tune - audible pre-igniton under power
    May 2018
    Seattle
    15
    I got the Overkill tunes for my 2013 Impala a few years ago, ran well on the 91 tune. After switching to the 87 tune I can hear it pre-igniting (or pinking as I call it) under power / uphill.
    I emailed Will a few weeks ago asking for help in solving this problem, have not got a reply.
    The question is, how do I solve this problem?
    I have the HP Tuners tool, I'm maybe hoping someone can help walk me through what data I need to collect, how to analyze it or what to look for, and what changes need to be made.
    The other alternatives I have are to put the factory tune back for 87, or take the car to someone with a dyno and spend some money on getting it dialed in.
    Appreciate anyone who might be-able to help me out.
    13,617
    Post the tune you are using now and a log file that includes knock retard in it.
    May 2018
    Seattle
    15
    Thanks for the reply.
    After posting I had the thought that after I flashed the 87 tune, I didn't disconnect the battery to reset/clear any stored data nor do I recall it going through a relearn period. Couple weeks ago I did that, noticed that it went through the usual relearn period, after that I have not been able to hear it pre-igniting (at least), and it seems to be running better than before - since its winter I cant be 100% sure that has fixed it.
    I'll capture a log next chance I get.
    May 2018
    Seattle
    15
    Attached is the tune and the log.
    The car has just had 100k mile service done 2 days ago, new plugs, EFI clean, all fluids changed etc.
    The fairly steep hill I can sometimes hear pinking is about 2 minutes in, after that just some random acceleration here and there on the streets back to home.
    Hopefully that has useful data.
    LH_IMP13_OK87_240302a.hpl
    Attachment 143459
    13,617
    The random part throttle knock is likely going to be hard to ever get rid of. It could be real or it could be picking up vibrations.
    The knock that shows up when you are deeper into the throttle it something you can try to work on. I'd personally try to make PE happen sooner to see if that stops the knock. Try lowering the throttle percent to 60%, lower the enable torque to 40% and the delay torque from 100% down to 40% as well. I'd be curious if doing that will help stop those knock spike around 3,000rpm and 70ish percent throttle.
    Sep 2021
    Kentucky
    556
    The changes to the cam timing are bs. I spent several hours on the dyno with a 16 impala and the gm tables were spot on. Picked up 2-3hp moving the tables 1* or less only out toward the top end.
    Mar 2022
    Indiana
    3,088
    Every knock event occurs during high MAP and Commanded EQ=1. Seems to me an easy fix would be to adjust PE so that it comes online when it needs to. See attached.
    You should be logging Cylinder Airmass to see where KR actually occurs.
    Also, MAF looks like it needs some work. Log Mass Airflow Frequency so you can make corrections.
    May 2018
    Seattle
    15
    Thanks for the info and file. I'll look for and add those options to the logging next chance I get.
    May 2018
    Seattle
    15
    I used the tune provided by SiriusC1024.
    Attached is the log from today with the extra options (hopefully I found the right ones!)
    LH_IMP13_OK87_240318a.hpl
    Same as last time the steep hill is around 5 minutes in, there was stop start traffic leading up to it from where I can stop somewhere and start the log. After that couple jabs on the accelerator here and there.
    Today was bit warmer around 65F, didn't hear any pre-igniting, seemed like it ran a little better with the PE changes, but hard to tell
    Mar 2022
    Indiana
    3,088
    Ok. Put High Octane, VCP, and Fuel>Gas spark back to stock.
    May 2018
    Seattle
    15
    These all appear to be in Spark > Advance:
    Base > High Octane
    Fuel > Gas
    VCT > VCP Spark
    Correct?
    Mar 2022
    Indiana
    3,088
    Yep those. Did you change them? If you don't have a stock reference there's a 2013 Impala 3.6 in the repository.
    May 2018
    Seattle
    15
    I have the original factory tune I saved before anything was changed.
    I'll make those changes, and get another log. Might be a few days again.
    May 2018
    Seattle
    15
    Here's the log after making the changes of those settings back to stock tune.
    PE_ST1_OK87_IMP13.hpl
    I also compared the stock tune in the repo, exactly the same as mine except for one flex fuel setting (mine aint flex fuel so is was disabled).
    Mar 2022
    Indiana
    3,088
    The VCT tables are different in the stock file. Did you put those back, too?
    May 2018
    Seattle
    15
    Yes these were set back to stock (double checked):
    Spark > Advance:
    Base > High Octane
    Fuel > Gas
    VCT > VCP Spark
    Mar 2022
    Indiana
    3,088
    Airflow>Variable Camshaft
    May 2018
    Seattle
    15
    All of the Airflow>Variable Camshaft settings back to stock, here is the log:
    PE-ST2_VVT_OK87_IMP13.hpl
    Mar 2022
    Indiana
    3,088
    If it's at a stock tune and you're still getting that much knock then it's a mechanical problem. Check for oil in the intake, plug condition, and do a seafoam cleaning through a vacuum line.
    May 2018
    Seattle
    15
    100k mile service was done a few weeks ago (new plugs, EFI clean (intake was removed to do that), all fluids changed), nothing unusual was noticed or noted.
    I might do the seafoam.
    Thank you for your help, much appreciated.
