Thread: 07 Yukon XL 5.3 Swap to a 6.2
    Nov 2022
    11
    Looking for some info here. I have an opportunity to get a 2012 6.2 l94 for a good price. I am wondering what all would need to be done to get it to run with the ECM. I currently have a flex fuel 5.3 with a built 4l60e 4x4. ECM is e38 that is currently in the vehicle. Can I use the same ECM with the engine or do I have to replace it? Thanks for any info in advance.
    Indiana
    331
    Find an OS number that matches yours and also came with a 6.2 engine. Segment swap the engine and engine diag portions into your PCM.
    "I don't care how it runs as long as it chop chops at idle"
    Oct 2014
    Moscow, Russia
    199
    Quote Originally Posted by horsepowerguru427 View Post
    It will be 12614088 OS on Escalade L92 with different throttle, different VVT actuator and without TCCM option.
    2011 Cadillac Escalade L94 w/LS3 valves and valve springs
    3,015
    You can use the same ECM.
    I'll bet your 5.3L didn't have VVT. If it didn't you could wire it like a 07 6.2L which did have VVT or you could simply delete it.
    Tuner at PCMofnc.com
