I really don't understand!, I've added turbo to my LZ4 with E38 ecm ith 60lb/h injectors but I'm not able to get the open loop rich.......... I set overboost to 0,8
I reduce injctors flow to enrich, I ' worked on the MAF even adding 20% , I've increased Airflow gain in open loop even of other 30% but nothing seems to enrich
I think closed loop is too much active (since A/F commanded is too much 14,6) I'd like to shut off over 3500 rpm and over ambient pressure when turbo start to push ...... but I'm not sure how to proceed.....
And also even if I worked on injector values, open loop flow correction, but nothing seems to change the situation (I'll share files in the apposite section)
