Results 1 to 14 of 14
Thread: OS 12585950 Manual Trans File
    Mar 2022
    24
    Anyone have a man trans file so I can segment swap this auto to man conversion. Thank you!
    405
    2,365
    How about a year make and model. I doubt there are very many people that have every OS number memorized.
    Mar 2022
    24
    2004 Silverado 5.3
    2,922
    have you checked all the 4.8 files in the repository?
    Tuner at PCMofnc.com
    Mar 2022
    24
    Yes
    SoCal
    1,604
    Searched through my library. Don't see a single manual trans with that OS.
    You're going to have to use a different OS.
    2,922
    In a pinch you can just disable all the auto trans stuff and tune away. You won't have reverse lockout but people have wired that to the brake switch.
    SoCal
    1,604
    Pretty sure I have a Silverado of that year with a manual. It will need factory programming with SPS/Techline Connect. If you don't have anyone in your areas you could send your module to me and I can factory program it and put your tune on it.
    405
    2,365
    Quote Originally Posted by hellbents-10 View Post
    2004 Silverado 5.3
    What is the VIN of the vehicle? I would almost bet there is an updated OS for it.
    SoCal
    1,604
    Looks like it does. 12587603
    It only modifies engine oil life. Still nothing with a manual
    405
    2,365
    Without knowing his VIN you can't say that OS is an update for his vehicle. And if it is there are a lot of M5 calibrations that use 12587603.
    SoCal
    1,604
    What I did is looked at approx 20 stock tunes of different variations and years that have that OS. All of them I ran through TIS. This was the only update I could find. You are correct. I do not have his VIN and I can not say with 100% certainty on other potential updates etc.
    Mar 2022
    24
    1GCEK19V54E119868
    Thanks for the help!
    405
    2,365
    If you go to this site https://tis2web.service.opel.com/tis2web/ and enter your VIN and look at the complete history for your vehicle the PCM should have been updated at some time after production and contain all the following segments. If your main OS is still 12585950 then for whatever reason it never got the updated calibration from GM. These are all the correct segments it should have. Once it is updated there will be calibrations available with same OS to do the segment swap.
    12587603
    12587682
    12587940
    12602137
    12578787
    12578797
    12585937
    12578993
