Results 1 to 9 of 9
Thread: *NEW* Duramax Injection Timing Calculator
    Sep 2022
    Alberta, Canada
    5
    Lightbulb *NEW* Duramax Injection Timing Calculator
    I have been working on a new injection timing calculator for a while now. It's easier to follow than some of the older ones floating around. The spreadsheets calculate the actual injector pulse width that is being used based on your injection pressure, injection duration and injection BTDC (%) based on your current timing. Currently, the spreadsheet calculates timing for the following Duramax:
    LB7 & LLY
    LBZ & LMM
    LML
    L5P
    I will add others once I can get my hands on some stock files.
    EDIT: v1.0.2 - fixed a couple mistakes with L5P calculator
    EDIT: v1.0.3 - fixed missing column on LBZ fuel pressure table
    EDIT: v1.1.1 - fixed problem with LLY-LBZ tables
    May 2023
    15
    Looks very nice. Only problem is that on my lbz the pulsewidth table uses kpa instead of mpa. When I paste the data in it causes err:502 in the calculated pulsewidth table below it. Am i doing something wrong?
    Looks like you did a lot of work on this. Thank you for freely sharing.
    Sep 2022
    Alberta, Canada
    5
    The units can be changed simply by right-clicking on the table in HPT, I chose Mpa as it is much simpler to have 2 or 3 digits instead of 5 to 6. I also cannot replicate your error, I looked up that error. It has something to do with an invalid argument. Are you copying your entire pulsewidth table into the spreadsheet?
    May 2023
    15
    I think the problem was that my base pressure table had an extra column in it and it pushed the data past the end of the table in the spreadsheet. I modified that and it seems to work ok now. thank you.
    May 2014
    14
    Your missing the 95 column in the fuel pressure table
    Sep 2022
    Alberta, Canada
    5
    Thankyou for pointing that out, I added the missing column to v1.0.3
    Jan 2006
    DFW
    249
    Thank you for sharing this with us!
    2008 Denali XL AWD LSA Blower
    2010 CTS-V
    2005 LLY Duramax SAS
    2015 Denali
    May 2014
    14
    One quick question on this is do you use the new data in the default timing table and then use the difference in all the other timing tables?
    Sep 2022
    Alberta, Canada
    5
    Quote Originally Posted by Silvergs72 View Post
    Yes, kinda. As altitude goes up, the timing needs to be advanced. I usually advance the mid alt by 1-2 degrees, and the high alt by another 1-2 degrees. Or you could use the calculator and increase the percentage BTDC by a little bit for mid and high alt maps.
