Results 1 to 11 of 11
Thread: Looking for stock tune or performance tune for Polaris rzr
    Mar 2024
    24
    Looking for Polaris RZR tune.
    Looking for stock or performance tune for a polaris rzr xp1000. Thanks.
    Mar 2024
    13
    Do you know the part number off of your ECU? 401xxxx? or 408xxxx?
    Mar 2024
    24
    Its a 2018 polaris ranger xp1000 ecm.
    Mar 2024
    13
    LOL, ok. First its a 22 rzr xp1000. Now its a 2018 Ranger xp1000. There are a LOT of different versions. Not going to get any help with vague and incorrect information. That is why the ECU part number is so important. Best of luck.
    Mar 2024
    24
    It?s a 18 ranger with a 22 rzr motor. we put it in because it threw a rod through the old motor. I need the rzr tune because the rzr makes more hp so the tunes are different. I?ll get the number today.
    Mar 2024
    13
    What intake manifold are you using? Wiring harness? You cant use the RZR tune with the stock Ranger intake manifold if that is what you are trying to do. Totally different.
    Mar 2024
    24
    All of the ranger parts fit right on to the rzr motor and it runs pretty good. I just want to see if the rzr tune makes a difference in power.
    Mar 2024
    13
    I don't think you are understanding. Your Ranger has a plastic intake manifold with a single throttle body. A RZR1000 has dual throttle bodies. If you put the RZR1000 tune in your Ranger with the single throttle body intake manifold it will throw check engine lights and run like crap. You can not do what you are stating. Leave the RZR1000 file alone. Tune the Ranger file that is correct for your parts or better yet maybe contact someone who can tune it for you. This path is not going to work.
    Mar 2024
    24
    I just want the tune so I can see what the timing a fuel need to be set at. The ranger has a large single Throttle body and the rzr has two smaller Throttle bodies so they should both flow about the same. And please stop wasting my time by replying if don't have the tune.
    Mar 2024
    13
    You seem to know more than me. I have the tune, but you can figure it out on your own. I wish you the best of luck.
    Mar 2024
    24
    Quote Originally Posted by AMartian View Post
    can you post the file if you have it? Thanks
