![Quote](images/misc/quote_icon.png)
Originally Posted by
fivetears
Pneudraulics - Fuels & Hydraulics. Military origin perhaps. Been a term of my vocabulary since July 1981; USAF Tech School.
Ok Robert, here's the anomaly: On the current 4L60E-HD2 instructions dated 28 Sept 2017; Page 4 - On the top righthand side of the page there's a block of text that reads, "Start Z bolts first...gaskets to case." Look at the word gaskets. Where the letters ke are, focus your eyes down to the second OEM hole; 1.25" straight down on the actual plate. Prior to 28 September 2017, the previous HD2 instructional PDF called for this hole to be drilled to .093
Not being sure of what changed, that rendered this hole diameter to no longer be enlarged to .093, was why I made the call. My new plate has this hole at .0775
Robert, GM has a new manufacturing process for the 4L60E valve body separator plate P/N: 24241783. Both snap on filter screens have been replaced by flat screens embedded into the case-side gasket. Even more, these new GM valve body gaskets are pre-adhered to each side of the new plate. This (I feel) poses new issues with drilling/enlarging fluid passages; namely a foreign object (FO) finding its way in between the layers of this new assembly. Yes sir... the potential exists. See pics. Drill bits tearing the gasket surfaces could be another concern.
So if you find your transmission steel check balls have hammered craters into your separator plate, and you buy a new one... this is what you get and have to deal with; beyond the current Transgo instructions.
