Results 1 to 9 of 9
Thread: 2010 Camaro SS Idle Surge
    Feb 2024
    4
    I have a 2010 Camaro. It has a 416 with a BTR 400+ cam. Sometimes I have to crack the throttle to get it to start. Once it stabilizes it is great until it drops to around 800 RPMs. I have searched the forums and am stumped right now. I am tuning in VE currently. Would anyone take a look at these and offer some advice please? Thanks in advance!
    SD tune surge.hpt
    Warm start up tune 12.hpl
    5BA8
    3,623
    It's not in speed density. You have the codes set to no error reported. It is running off the MAF.
    It's overly rich for one thing.
    You aren't logging your timing advance so you have no idea what's going on there. You can't see your idle over/undershoot activity because you aren't logging your advance.
    You have too much idle timing in it.
    Stopped looking after that.
    Oh yeah, looks like the VVE has not been touched. Definitely hasn't been adjust around idle area.
    email=[email protected]
    Feb 2024
    4
    Thank you I will go back to the beginning.
    Feb 2024
    4
    Thank you again for looking at my post and digging into the setup and datalog a little bit. I do appreciate your expert advise. I do have some questions and I will put them in the order that you put your responses since I would love some good feedback.
    I looked at everything this afternoon and I have the MAF set to fail at 1 Hz to put it into VE. After I did that it set a code for the MAF (which I expected it to) and as a result, put the PCM into limp mode, i.e. REP. Therefore I turned off the error reporting and that fixed the REP issue. Are you positive that I am not in VE?
    About the richness; yes, it is rich but not pig rich; if I can get it to idle long enough to start tuning the VE tables I will take care of that. It is very difficult to drive like it is and tune any idle tables as the idle is fluctuating wildly between 500 and 1000+ rpms.
    The spark tables are what was in the PCM when I got the car. They might not be stock but I can adjust those. If you have any pointers i would greatly appreciate your feedback.
    I just need to know if someone could help me with getting this thing to not start idle surge at approximately 69 seconds of run time.
    Mar 2009
    Andover, MN
    538
    Did you have a new tune to post with the updates Ed suggested to change? Otherwise we are just guessing on what was changed. If you do have a an updated tune, post a log with timing.
    Feb 2024
    4
    Quote Originally Posted by ns158sl View Post
    There were no changes as I didn't see anything that Ed suggested except he suggested to log Timing Advance. I will have to do that tomorrow as I am not at the car. I believe that it is in Speed Density but I may not be correct. Did I set it up incorrectly? Could you verify that I am or I am not? If I set it up incorrectly I would love some input. I thank you for looking into it.
    Mar 2009
    Andover, MN
    538
    Need to set the maf faults to error on first. Also seems like e38s like to have the maf fail freq something other than 0, so maybe 4 hz and 6 hz. Lower your idle timing 3-5 degrees. Why did you globally lower the HO and LO spark tables 5 degrees. I'd leave that alone for now until you can get it to idle. Its pretty rich. Your o2's are railing around 900mv.
    Tuning Addict
    6,902
    You can add MAF state to your channels and that will show if it's failed or not. Typically when it's set to no error, it won't fail it. Depends on the OS and routines it runs. It may even fail it, then try running on MAF again and then switch back and forth. Best to set it to fail on the first error. If it's going into REP, you might need to change some of the map test settings. Make sure it's offset values are pretty high. You can also tune without failing the MAF using a math formula, but that's up to you. I normally tune in the MAF and rough in the VE at the same time even if I'm going to fail the MAF and tune the VE in the old way. Doing it like that will usually keep it from going into REP from the two models being so far out from one another.
    This is what I use for my own reasons. It just makes the VE match the MAF. If you have a stage 3 or bigger cam, it can cause problems with it.
    (([16.71]+([16.71]*([50116.156]/100))-[2311.71])/[2311.71]*100
    Cringer also has a method along with Smokeshow if you want to look for those. Cringer's uses dynamic airflow whereas Smokeshow's uses airmass.
    ~Greg Huggins~
    3,007
    Quote Originally Posted by JimmyE38 View Post
    The idle will likely work itself out as you get the tune closer. If you try to address it now it will be off when the fueling is correct.
    I'd strongly recommend looking into VVE tuning. It is going to be an absolute must for this car.
    Tuner at PCMofnc.com
