Results 1 to 15 of 15
Thread: Pro-Link Wiring to AEM 30-0300
    Nov 2020
    Can someone please validate how to wire the Pro-Link to the AEM 30-0300? Its a non CAN BUS LS1.
    Pro-link Directions
    - Black ? GND --> This is clear
    - Red ? Analog 1 --> Which AEM wire? White? or Brown?
    - Blue ? Analog 2 --> not used if I use the Red wire?
    - Orange ? CAN High --> not used in my application
    - Yellow ? CAN Low --> not used in my application
    Its been frustrating try to find a clear answer. Almost everything I have found is how to get he AEM CAn guage to read analog, or something like that. Any clarification is appreciated, I just dont want to change burning this thing up.
    Prolink black to aem brown
    Prolink red or blue (your choice) to aem white
    That is it
    Instructions:
    Pro-Link
    AEM 30-0300
    Jul 2021
    5
    Quote Originally Posted by r0cket View Post
    Pro-link Directions
    Jul 2021
    5
    r0cket did you ever get yours working? I am having the same issue with the 30-0300 and the prolink. The wiring instructions are so simple and every video makes it too easy to understand and hook up, yet it doesn't read in hp tuners properly. I couldn't get it to work with the serial Port so I gave up on that route. I'm starting to think I have a defective guage..
    SoCal
    1,851
    Had this issue also. Turned out to be my settings in the scanner. I was using the wrong input. When I get home I will check and see what it was I did.
    Jan 2021
    30
    following
    Jun 2023
    3
    Did you figure out what setting you changed?
    Sep 2012
    CA
    51
    I'm having issues with the serial for my AEM wideband also. The Prolink works fine. But when I hook up to Serial, I am seeing a 18.3EQ ratio being read in the scanner. It just stays stagnant at that number when the engine is running. Transforming the output makes no difference. I read somewhere that the pin # on the serial plug might be off. Pin #2 Rx and Pin #3 Tx output. I might try switching the wires to see if I get any data that way.
    Apr 2023
    Quote Originally Posted by chrisxiv View Post
    I'm having the same issue. Let us know what you find out
    Oct 2023
    8
    Old thread, but still following. 😅
    Feb 2024
    5
    Pro-link Directions
    I just dealt with this today installing my pro-link/mpvi3/aem 30-3000 wideband. Wired everything up using the white analog output from the aem to the red on the pro-link, and the brown from the aem to the black of the pro-link. I could not get the channel to display the same AFR in VCM scanner as the gauge was showing. After hours of research and trying different things, I finally found the white analog wire pin had came out of the connector on the back of the gauge. Seems to work great now!
    Jul 2020
    Las Vegas ,NV
    19
    I am currently using an AEM 30-0310 and can read AFR but not Lambda. I have been using Goatropes set ups can use the Maths to and log MAF to see AFR % difference but no changes get me to Lambda. I have the MPIV1 so I must use the serial connection. The funny thing is ,I also have an EFI V-2 and can read and log both AFR and Lambda. Anyone have any ideas. I really would like to use HP to correct the MAF andd the VVE as the process looks much simpler. Thanks in advance.
    Lanny
    Apr 2023
    Colorado
    18
    Hey there, I?m getting ready to set this up. I know this is an old post but I was curious if you got yours to work properly? Just trying to decide if I should try and sell this 0300 for a different model.
    Jul 2020
    Las Vegas ,NV
    19
    Quote Originally Posted by tmontel21 View Post
    Im sorry to say that I could not read Lambda in HP only AFR, but It does work with my EFI Live. I have probably failed to make some unknown to me correction in the values. Im sure it is just me and not the instrument. I was afraid I had a counterfit model but after investigation, it appears to be the real thing. I never received an answer on this forum, yours is the first reply.
    2,779
    If you can log AFR, you should be able to use a math channel to set Lambda.
