Results 1 to 3 of 3
Thread: 2020 l5p issues after swapping tcm
    Mar 2024
    engine reduced power all tc/esc lights on truck gear indicator doesnt work(wont show PRNDL) has a lot of codes had to disconnect batteries to shut truck off followed their instructions on swapping tcms
    infolog below
    2024-03-24 9:56:42 PM
    VCM Suite Product: VCM Scanner 5.1.2449 Beta
    Operating System: Windows 11 (build 22621)
    Microsoft .NET: 6.0.28, 4.7.1 or later
    CPU: Intel(R) Celeron(R) N4020 CPU @ 1.10GHz
    Available Memory: 1,189 MB
    DpiX: 96, DpiY: 96
    OS Database: 2022-10-11
    OS Mods Database: 2022-10-11
    Device ID: 2181815585
    Credits Purchased: 8
    Credits Used: 8
    Credits Available: 0
    Licensed Features: Pro Feature Set,
    [Specific Controller]
    GM E41, 3A20070200700085, (8)
    ConnectionMethod: USB
    HardwareVersion: 2.1.2
    ManufactureDate: 2023-08-03 7:09:14 PM
    PartNumber: 6250
    FirmwareVersion: 5.3.45
    FirmwareStageName: Release
    FirmwareControllerGroup: 0
    PoweredOnTime: 00:01:59
    VehicleConnectedTime: 00:01:57
    VehicleDiagnosticConnector: 1
    Bluetooth HardwareVersion: 2.3.0
    Bluetooth FirmwareVersion: 1.0.0
    Protocol Info: ISO 15765-2: Standard 11 bit Normal, J1962: CAN 500 kb/s
    ECM: 7E8, CAN, ECM -EngineControl - E41, GM, 2017+ 6.6L Duramax
    VIN: 1GT49WEY9LF257670 - 2020 GMC Sierra 3500 Denali, 6.6 L, V8
    Serial: 3A20070200700085
    Programmed State: Fully Programmed
    Boot OS: 12723940
    OS: 12718488
    Calibration IDs: 12718488, 12719455, 12719379, 12666733, 12678346, 87836557, 87836559, 13536793, 13526562, 13530651, 13536797, 12719473, 12719572, 12719540
    Calibration VNs: 00007525, 00009034, 00007EE5, 0000FB1D, 00009661, 0000F5E9, 0000900D, 000049C1, 000046DC, 0000AAA8, 000046B1, 00006C91, 00005617, 00004AF4
    Basic PIDs: 67
    Trouble Codes:
    P0700 - Transmission Control System (MIL Request) (Pending, Current)
    P1919 (Pending, Current)
    U0101 - Lost Communication with TCM (Pending, Current, Permanent)
    Controller Type ID By OS: 41
    None: 7EA, CAN, TCM -TransmisCtrl - T93, GM A10/Allison 2019+
    Serial: 61230740000X0076
    Boot OS: 24296531
    OS: 24295683
    Calibration IDs: 24295683, 24042985
    Calibration VNs: 00005D42, 00009C0D
    Basic PIDs: 4
    Trouble Codes:
    P27A7 (Pending, Current, Permanent)
    P27AA (Pending, Current, Permanent)
    P27AB (Pending, Current, Permanent)
    P27AC (Pending, Current, Permanent)
    P27AD (Pending, Current, Permanent)
    P281B - Pressure Control Solenoid "H" Control Circuit/Open (Pending, Current, Permanent)
    U0100 - Lost Communication With ECM/PCM A (Pending, Current, Permanent)
    P182A (Pending, Permanent)
    P182B (Pending, Permanent)
    P182D (Pending, Permanent)
    P182E (Pending, Permanent)
    P1839 (Pending, Permanent)
    P1840 (Pending, Permanent)
    P27A8 (Permanent)
    P27A9 (Permanent)
    Controller Type ID By OS: 73
    None: 7ED, CAN, BSCM-BrakeSystem
    Calibration IDs: 84744979, 84561049, 84561079
    Calibration VNs: 00007CFF, 00001132, 00009FB0
    Basic PIDs: 3
    None: 7EE, CAN, GPCM-GlowPlugCtrl
    Calibration IDs: 12704709, 12688412
    Calibration VNs: 00009C94, 00004BC1
    Basic PIDs: 6
    Advanced Tuner projectlnf's Avatar
    Jun 2012
    warrenton va
    479
    Post your file so we can help.
    But it sounds like you need to flash a file to it so the TCM knows what it?s supposed to do.
    Unsure on this because I have only done a few L5P TCM?s
    Tuner Alex14SS's Avatar
    Aug 2021
    Florida
    92
    Firstly, the variety of codes, especially U0101 (Lost Communication with TCM) and U0100 (Lost Communication With ECM/PCM A), point towards a communication breakdown between the ECM and the new TCM. This could be due to incorrect installation, a fault in the TCM itself, or potentially incorrect serial/hardware that doesn’t match your truck’s specifications (PCM/ECU)
    The engine power reduction and the lit traction control lights, paired with the gear indicator not working and the myriad of transmission-related codes like P0700, which signals a broader transmission control system issue, suggest the new TCM isn’t correctly communicating or operating with the rest of your vehicle’s systems. The specific P27 series codes (P27A7 through P27AD, P27A8, P27A9, and P281B related to pressure control solenoids) imply there’s a deeper issue within the transmission control, possibly linked to how the new TCM is managing pressure control solenoids or interpreting signals from the ECM. The first step should be a thorough check of the TCM installation to ensure it’s properly seated, and all connections are secure and not damaged.
