Page 7 of 7 FirstFirst ... 34567
Results 121 to 124 of 124
Thread: ZF8HP70 fails 1>2 shift under WOT
  1. #121
    Jan 2022
    935
    that does not matter
    post the answers anyways : )
    what does tazer see for tire diameter?
    what does scanner see for tire diameter?
    what does scanner see for gear ratio?
    what is the actual (measured) rollout of your rear tire?
    what gear is in the car?
  2. #122
    Jan 2022
    935
    28.18"
    26.35"
    3.42:1
    90.7"
    3.70:1
    mine ^^^
  3. #123
    I was telling you i was told it made no difference, and that even with factory gear and tire, it still had the same issue. but i did change thegear and tire size in the scanner. Gear is 3.70 and tire is 28.8. As for the tazer im not sure what it reads, i dont know how to check
    2019 challenger rt
    k&N cold air intake
    92mm hellcat throttlebody
    ported 392 intake manifold
    ported eagle heads
    Cammotion custom 222/234 cam
    stainless works long tube headers and catless mid pipes
    3' catback with h-pipe & pypes violator mufflers
    e-85 tuned
    3.70 lsd
  4. #124
    Jan 2022
    935
    here
    what value does it see for tire diameter?
    [email protected]
    don tanklage
