Results 1 to 2 of 2
Thread: Get unknown error code 8A
    Mar 2024
    Hello,
    I have a 07 Colorado that I'm trying to tune. Load all my HP tuner stuff onto new laptop.
    Pull the stock file off the truck
    Purchase Lisc update key on cable and make tune changes
    Go to reload tune and it times out (bootleg timed out)
    Tech support tells me it is a car issue, so I do some checking pull fuses and relays and such. Iet the cable to do a "write only" on the truck and try to do a "write entire" on high speed or slow speed. Finally, I get a "unknow error code 8A"
    The vechicle will not start or crank now
    Any help would be great! Thanks in advance
    - Shana -
    28,313
    https://forum.hptuners.com/showthrea...897#post139897
    Typically a battery or wiring issue with the vehicle. This guy had a dakota digital air ride system that was interfering just as an example.
