Page 26 of 27 FirstFirst ... 16222324252627 LastLast
Results 501 to 520 of 524
Thread: lean area around 2500ish rpms-2014 ctsv
  1. #501
    Feb 2018
    846
    I'm sorry for not being completely read into this problem but could someone give me a summary?
    I've done a ton of CTS's and LSA's. I actually even did the first production LSA CTSV ever made for Rick Hendrick before they were out. I personally daily drive a '17 SS with a LSA. Never noticed any lean spikes. The VVE table will have a hump at lower RPM/high boost that falls a bit before taking back off. I also set most up in SD only because you can hit the same spot in the MAF passing someone on freeway with 6th gear/locked TCC and be lean but rich if you did a standing start full throttle pull.
    Those having problems... have you tried going 100% SD?
    Turn off injector desoot mode?
    The VVE table will definitely look different than a NA, centrifugal, or turbo.. but similar to any other whipple/magnacharger VVE table.
    going 100% SD- yes lean spot still there
    turn off injector desoot mode- Mine has been off since I bought the car in 2015
    It seems that it only has happened to a handful of us. However Jayrolla uncovered a few ctsvs on the dyno and right at 2600 rpms they go lean then go right back to commanded (post #482)
    Here's what it looks like...ignore the KR this a very old snapshot of a log. Notice the maf and VE airflow is actually higher than DYN air at that point.
  2. #502
    Attached are two VVE tables from the last two CTSV's I did.. My notes say one was a 388 with 231/247 duration cam 1300 ID injectors
    The other was a stock CID 223/235 1050 Id injectors
    I don't even remember the cars to be honest. I just wanted to show what I find to be a typical looking VVE table for a LSA or really any PD style blower.
    Attachment 144563Attachment 144564
    Heres an example of the VE and a snap of log.
    AFR target a little lean here, but can see the massive peaks needed to keep the AFR on track.
    Cylinder airmass shoots up as a result, but car drives smooth despite this.
    This is the HPT 2Bar OS, no VVE, no MAF.
    2017 HSV Clubsport R8 LSA 30th Anniversary M6 - GMM triple-step headers, Cat delete, Stock HSV catback, Harrop pod intake, ID1050X injectors, KB BAP, 2.35" Griptec pulley w/ Gates RPM belt, FII blower & lid spacers, FII reservoir, Mantic 9000 ceramic clutch, Elite Eng. catch can, AEM 30-0334 wideband
  3. #503
    2,940
    Quote Originally Posted by L1FTD View Post
    In my opinion those peaks aren't unusual except they should be interpolated between the two and carried to 0 RPM. Look at the VVE tables I posted. That shape is pretty common with all PD style blower.. And not like turbo, centrifugal, or NA
    Tuner at PCMofnc.com
  4. #504
    Jul 2020
    VIC Australia
    1,196
    This is important.
    L1FTD and I have virtually identical cars. Same base OS. Similar power levels. Different aftermarket components. I don't have this issue. Just got lucky. If L1FTD was in a position to re-install his maf and revert the OS back then we would be near twins save for injectors and cam grind.
  5. #505
    Feb 2018
    846
    This is important.
    Really wish I was one of the lucky ones....lol.
  6. #506
    Feb 2018
    846
    so, if you interpolate then the area between 1600 and 2600 is going to be very rich. Would you just leave it like that?
  7. #507
    Jul 2020
    VIC Australia
    1,196
    Quote Originally Posted by sgod1100 View Post
    Cryptically what I'm trying to say is there's a combo of parts and / or a tuning strategy (mafless, custom os etc) that has to be causing this. I can't imagine in stock form this problem existing at the oem. If any of you could take a hit for the team and roll changes back towards stock both mechanical and tune and share the findings here, I think that knowledge would be extremely valuable should it prove that this problem is self induced and more importantly what component or strategy influences it the most.
  8. #508
    I was running the VVE before I switched to 2Bar OS, still SD. I had more interpolation between the peaks, like a little hammock, not as dramatic. It was just harder to get the fuelling right, adding so much fuel to a column would pull the surrounding up. Always ended up rich before and after the lean spike.
    Switched to the 2Bar to hit the lean spikes exactly, no interference from coefficient calculations.
    The massive peaks work well, gets the fuelling spot-on before/during/after lean spikes, drivability surprisingly not affected.
    The thing is, it just seems so unnatural? Like a diagnostic? Or mechanical interference?
    In the space of 200rpm, the fuel demand shoots up 15%, then right back down? Twice.
    This is important.
    You are a very lucky man!
    Piecing it all together, it seems the bigger HP cars dont experience this, or at a lesser extent.
    Bigger HP on the LSA usually means getting rid of the factory FSCM and doing some further fuel system upgrades.
    The ID1050?s only ever see a max of 50% duty cycle. Thats probably not helping me.
  9. #509
    Australia
    1,998
    just a thought but when this is tested with the vve does zeroing or changing the ''prediction coefficients'' help it at all ? i know most dont touch that so a predicted event could always be happening no matter the vve adjustments ? just throwing a thought out there
  10. #510
    Its hard to keep track, but its been narrowed down by members here.
    Problem exists in blended, MAF only (not possible, but anyway), VVE SD, 2Bar SD.
    Problem exists on an LS9 ZR1, stock exhaust/o2, big injectors only mod.
    And my first sighting of it, after intake, headers, no cats, stock injectors.
    Between my car and the LS9, we almost cancel each other out back to stock. He has injectors as only mod, I have intake/exhaust as only mod (stock injectors). Both have the problem.
    I know what you mean, it could be a simple tune thing, maxing a table that shouldnt be or something. Theres just so many guys with the same problem.
    Ill have a close compare of mine and your tune, try a few things that stick out.
  11. #511
    2,940
    I wouldn't think that is the case. The ones I show don't cycle rich/lean.
    One thing I want to point out too which might be the whole cause of the confusion.
    This area you guys are talking about is very susceptible to transients. Its really hard to be steady state under heavy load at 2500 RPM if its not a manual trans. So if you aren't carefully filtering out quick pedal movements or fast MAP changes you're going to see lean spots just because it is a transient. If you move the pedal quickly.. there will be a fraction of a second where the WB will show lean. This is OK and not something you could really fix.
    When I'm dialing in this area I'll take the car to the freeway where I can run 80 mph.. Manually shift into 6th gear (AUTO) with the TCC locked up.. Start at 60 mph, lean into the throttle to make say 140kpa, then same thing but at 160 kpa, then full boost, etc.
    but as steady as possible is the name of the game.
  12. #512
    Ive currently got them ?zeroed?. Theyre not all zero, but ive removed the coefficients, so to speak.
    All MAP and TPS are zero. Current and Old are zero. Corrected is zero. Base is 1.
    Ive tried stock prediction, and changing the coefficients in the zones the lean spikes exist.
    No change to lean spikes, just tip-in as expected.
  13. #513
    sgod1100, myself, and most of the other gentlemen here are M6 trans. I believe.
    I can go WOT from 1000rpm, and lean spikes show up the same.
  14. #514
    Feb 2018
    846
    Yes, that's correct. I've been steady state in those areas many times and they will still show up as lean
  15. #515
    Advanced Tuner PGA2B's Avatar
    Nov 2004
    St. Louis, MO
    476
    I have an A6 and don't notice it as much when I am not in manual mode. The stock A6 shift points take into consideration these spots I feel. In manual mode, I can reproduce the lean spots everyone is seeing.
    2013 OBM A6 CTS-V Coupe
    Mods: Headers back Billy Boat Exhaust, GripTec 2.65, 8.6 PowerBond Lower, LSX Innovations Solid Isolator, ID850's, NGK TR7IX's, Accel 9070CK Wires, Spectre CAI, SRI Ported Throttle Body, SRI Catch Can, NGK AFRM, 160* T-Stat, 0fx2gv Brick, Hard Line Delete W/3/4" Lines, FB 101 FMIC, Pierberg CWA50, Stoptech Drilled/Slotted Rotors, EBC Redstuff, Cut Stock Springs, Flat Bottom Steering Wheel
    2006 Black Raven STS-V (Traded In)
    Fully Modded: 459RWHP@5888rpm/451lbft@4696rpm
  16. #516
    Advanced Tuner JayRolla's Avatar
    Mar 2021
    248
    This is pretty much how mine came out. And yes if I interpolated between the humps I would be rich in-between the lean spikes at those two rpm points. Even with these humps and little humps in the MAF curve I still go slightly lean. You dont feel it as much but can be seen on the WBO2 and yes I am steady state throttle.
    I also had this issue on stock injectors. Just intake, headers, xpipe, no cats.
    2013 CTS-V Coupe M6 - 1 7/8" Headers, 3" x-pipe, stock mufflers, Airaid intake w/green filter, ID1050X injectors, DSXtuning flex fuel kit, DMS under hood tank, upgraded pump, 3/4" lines, griptec 2.4" pulley, solid isolator, 100mm idler, reinforced brick, MM mild catch can, AEM 30-0334 wbo2, 600whp/630wtq
  17. #517
    Mar 2021
    248
    Race Proven Motorsports posted a new 5th gen ZL1 video. Same issue. So it looks like this is pretty much happening to all these motors. I reached out to Fran the tuner/owner and he said he doesnt see this as a bad lean spike at WOT and to email him this thread but he never got back to me. Im just going to move past this and not worry about it. Peaks in the VVE, MAF tables, raped PE table.
  18. #518
    Quote Originally Posted by JayRolla View Post
    I watched this video after you mentioned it.
    False alarm, there is no lean spike! None of us have a lean spike!
    He was certainly dismissive of your comments. To the point of even denying the AFR spiked lean at the rpm youre talking about.
    Anyway, I agree. If the fuel is getting there one way or another, all is well.
  19. #519
    Feb 2018
    846
    pfftt..doesn't see it? or IGNORING it? lol.
  20. #520
    Feb 2018
    846
    13.5 AFR with 9.5 lbs of boost...yeah no big deal..lol
