Thread: 2017 Silverado 4.3 swap for Gen 4 LS
    Nov 2023
    6
    Hey folks,
    I have 2017 Silverado 1500 with 4.3 V6, Z71, and towing packages. The truck has 100k miles now and I'm certainly not going to fix and keep the 4.3. I am researching options for a v8 without losing much if any functionality. I have a LOT of gen 3, 4 engines and parts. I just realized that the L96 6.0 was used on 2500's through 2017.
    Is there any way I can swap a gen3/4 LS into this truck using whatever GM used to put L96 in the 14-18 trucks?
    13,604
    Nope. The 2017 truck you have is direct injection. The L96 and other engines from before 2014 are port fuel injection.
    The L96 uses a E78 controller and the 2017 uses a E92 in V8 applications, I think it's the same in the 4.3 too.
    You'd need to swap in a L83 or L86 if you wanted to keep things more simple.
    Nov 2023
    6
    Aye but if I have to replace the controller and the injector harness anyways to go V8, can if I move to an E78 controller and have support for a port injection Gen 4 engine? And keep the advanced body-control/integrations/features seen in 14-18 trucks?
    Arizona
    268
    Trust me, just do an L83 or L86 swap and segment swap the PCM. You'll be thankful you did.
    2009.5 PBM G8 GXP M6 W/Roof-Self tune, OBX LTs, Kooks axleback, LSA blower, cam,
    Monster LT1-SC clutch, flex fuel, 12 psi [email protected] 1,800 D.A
    2007 TBSS-Self tune, bolt ons [email protected], 1,900 D.A
    1991 GMC Syclone- Self tune/catback 12.8@104, 4,200ft D.A
