Page 3 of 4 FirstFirst 1234 LastLast
Results 41 to 60 of 67
Thread: 4.8 LS swap into 1988 c4 corvette
  1. #41
    Mar 2024
    Kentucky
    45
    I'll be starting on it in the next week or so. Got the engine sitting here along with most of the additional parts.
    That?s great an I wish you the best on your build sir
  2. #42
    Mar 2024
    Kentucky
    45
    my most recent log 1 st run in driveway (1).hpl
    Does anyone have any input thay can share tune2.hpt i have tried to adjust my injectors but i dont think im doing it right. they are from a 6.0 part number for injectors is # 12580681
  3. #43
    Mar 2024
    Kentucky
    45
    Im struggling with these injectors. i cant seem to get the flow rate done correctley . Can anyone help me because im lost
  4. #44
    Mar 2022
    Indiana
    3,047
    Is your fuel pressure regulator vacuum referenced?
  5. #45
    Mar 2024
    Kentucky
    45
    can you explain that ?
  6. #46
    Mar 2024
    Kentucky
    45
    my injectors are ls4 injectorspart # 12580681 30 lb/hr @58psi
    The tune i have is saying 24.2 lb/hr some how i need to get the flow rate on my tune to be 30 and then then interpolate from 0 kpa to 80 kpa i need to interpolate this an thats where im confused on what to put
  7. #47
    Mar 2024
    Kentucky
    45
    my regulator isnt ran off vacuum if thtas what your asking sir
  8. #48
    Mar 2022
    Indiana
    3,047
    Here it is.
  9. #49
    Mar 2024
    Kentucky
    45
    Here it is.
    ive been trying to figure the math out for two weeks . can you explin how you figureded it out please
  10. #50
    Mar 2022
    Indiana
    3,047
    I got it from a 2008 LY5 tune (avalance, silverado 1500, etc). The column labels use different units, but it's easy to get it moved over.
    https://forum.hptuners.com/showthrea...l=1#post775252
  11. #51
    Mar 2024
    Kentucky
    45
    today i actually drove it down my street an heres my log file . still cant figure out why im not getting my o2 sensors to read an it was like dying out when i tried to throttle the car so i basically coasted an was able to give just a little gas . Also my ltft an stft arent reading either drive on street 2nd trip.hpl
  12. #52
    The fuel trims can't work until you fix the oxygen sensor problem.
  13. #53
    Mar 2024
    Kentucky
    45
    Quote Originally Posted by gametech View Post
    what could be the cause of it ? its all brand new
  14. #54
    1,565
    Problems on swaps is usually wiring issue. Very common for purchase harnesses to have issues.
  15. #55
    5BA8
    3,529
    O2s look disconnected.
    email=[email protected]
  16. #56
    Mar 2024
    Kentucky
    45
    One was hit not the other
  17. #57
    5BA8
    3,529
    Quote Originally Posted by Corvette Chris 39 View Post
    Both of them in your last log were flatlined at 448mv roughly. Both looked identical.
  18. #58
    Mar 2024
    Kentucky
    45
    ii put new ones on it today an now i cant get the car to even start at all . What do you think made this happen
  19. #59
    Mar 2024
    Kentucky
    45
    So when im cranking it over an using vcm scanner , my log isnt showinh spark for some reason. Im so confusesd
  20. #60
    1,565
    Post the log.
    If it was me though, I would get the wiring diagram for my donor ECM and check every connection, both for where it lands and for proper connection.
