Results 1 to 6 of 6
Thread: IS38 tune file for 1.8L
    Mar 2024
    7
    Hi, I am looking to swap turbo and I would need a tuning file to start my car. Does anyone have that in stock ?
    May 2014
    USA
    627
    the car will run just fine on a stock tune file with the turbo swapped
    biggest limitation will be fuel-- the 1.8 hpfp does not flow very much. 2.0 hpfp/vac pump can be swapped, but hptuners doesnt have the tables needed to make that work right. However this would work OK for pump gas / light E mix setup. MPI is of course the ultimate solution.
    you'll need the "boost/wastegate logic" OS patch or you wont be able to properly tune boost. It's only on a few OSs and I don't know if it's been added for any 1.8 files.
    Mar 2024
    7
    I am new to this, which table or specific modification would be required for my application ? How does the patch work ?
    Mar 2024
    7
    Could you help me if I share my Stock file ?
    May 2014
    USA
    627
    Sure, I can try
    Mar 2024
    7
    Hi, there is my stock file. Could you help me to start for an IS38 setup ?
