Page 2 of 2 FirstFirst 12
Results 21 to 26 of 26
Thread: 2018+ whippled scat packs issues
    Aug 2017
    Quakertown PA
    547
    All I'll say is I have NEVER ,and I mean never had this issue with Kenn Bell, BDS, Merc 800-SC. Eaton ,Weind ,Procharger. on a G3 hemi, you pick the year(up to 2023, haven't done one yet)
    04 RAMGTX........ 8.82@154mph 392Ci G3Hemi 3250lbs 2.6HP/Ci Naturally Aspirated
    05 Rumble Bee 13.29@101mph STOCK 5.7l , Just a tune, still runs OEM airbox
    09 Challenger Drag Pak 8.65@160mph 426Ci G3hemi 3650lbs 2.4HP/Ci Naturally Aspirated
    G3 Hemi Videos
    Sep 2021
    14
    I have a 2013 w a single turbo and it has a 8 misfire. Under boost only 4psi. Built 392 5.7 w swapped couls, injectors, plugs, cp is 198. No visual damage to cylinder and when it happens, occasionally it continues to miss after your off the throttle and idling. Never been able to get the hood open quick enough to move the harness or listen for injector pulse.
    No detonation. I am at a loss past overlaying the injector and coil for number 8.
    5BA8
    5,447
    Start your own thread.
    email=[email protected]
    Advanced Tuner 2therock's Avatar
    Jun 2009
    N. GA
    549
    So I take it there is no positive ID on the root cause? Yet? Not trying to hijack thread just chiming in and listening with high hopes.
    No one here has mentioned an Edelbrock 2300 TVS 7psi, so add that one. Two or three from highway speed WOT kick-downs and get the P0308 when letting off. Normally no felt miss. If it does cycling power it goes away, still have to reset the CEL.
    I hope I can find a harness to try. 2013 R/T. If one of you guys swapped harnesses without success and want to recoup $$ from the extra that was not bad let me know.
    2013 Dodge Charger R/T Plus, Stock 5.7L, Edelbrock E-Force Stage 1, 3.25" Pulley, 450-HP 459-TQ.
    Corsa Sport CatBack, 3.06:1 Wavetrac, Dual Fans, 1-7/16 Radiator, Mopar Oil Cooler
    2005 Radix'd Silverado L33 5.3 ECSB Z71 @ 387-HP 395-TQ
    Quote Originally Posted by 2therock View Post
    Datalog the number of misfires, cylinder by cylinder and total. Look at how many misfires you are getting on a drive cycle. My cammed, supercharged (Whipple) 5.7L likes to kick up a P0308, when logged it is like around 20 or so misfires. A guy who helped me with my tune said he wasn't concerned with it on a cammed HEMI.
    I am not the guy that tunes transmissions, our username is similar. If yo message me about I am not replying anymore.
  6. #26
    Jun 2009
    N. GA
    549
    Thanks.
