GM PN# 89017847
AC Delco PN# 323 1640 A22
If I understand correctly this is the "truck starter" lots of folks prefer for LS3 applications.
I have an LS3 crate engine with a cam that isn't outrageous, but not stock. Space for the starter is a MAJOR constraint. This starter is absolutely at the limit of what can fit.
Is there an option someone can recommend for a starter that can handle a stock compression ratio LS3 while being less demanding in terms of voltage and space?
I am also going to approach this issue from the battery-strength side of the equation as well. Current battery is an Odyssey PC925 (AGM).
