Results 1 to 20 of 21
Thread: help with not idling after stop when coming down from 40mph or higher
    Nov 2023
    28
    i have a 6.0 ls which if you drive easy its ok when you decelerate from above 40mph it will chug and die at complete stop unless you feather throttle at stop alittle then will stay idling but will start right up if dies plz help
    2,111
    As always, tune and log needs to be posted.
    5BA8
    4,335
    FFS how can anyone help without a tune file and data log???? Seriously......
    email=[email protected]
    8,862
    It's a 6.0 LS, aren't they all the same? You guys must not know much about how these things work.
    GM Gen4 Injectors v2.1.xls
    ChatGPT is the end result of someone assuming that if they gather up a large enough pile of sh*t it will spontaneously generate a pony.
    5BA8
    4,335
    That's why I got this!!!! Muhahahaha!!!!!
    Nov 2023
    28
    Idling concern and running lean
    gary 6.0.hpl
    its also running very lean to lean to drive dont want to hurt anything i have 52psi fuel pressure which is oem specs any help plz
    original tune 6.0_CL_Enabled.hpt
    Nov 2023
    28
    Tune posted sir
    Nov 2023
    28
    Tune and file posted sir
    3,449
    You won't hurt this setup being too lean.
    The drivers side o2 sensor looks suspect. The fueling needs to be gone over.
    Tuner at PCMofnc.com
    5BA8
    4,335
    You have something going on with bank 1. It has the fuel trims pegged at +50%. Need to check the header temps with a temp gun. Might have multiple dead cylinders on that side causing a bunch of raw O2. Bank 2 is not near as bad.
    Nov 2023
    28
    did some testing found plugs were black and wet replaced plugs checked compression have 180 across the board. have no cylinders missfiring and have 52psi fuel pressure and it still buries my fuel trim to positive 50 is there a chance i can ajust my numbers in ve table in this area to lower my trims or not work that way plz help also have no vacuum leaks any suggestions plz
    Arizona
    830
    any suggestions plz
    Every change you make, such as replaced the spark plugs, you need to run a log and post it here for us to see.
    Your tune and your data log needs to be posted.
    Or else we are like slow-poke rodriguez,nothing gets done.
    But yes, altering your VE table, and your MAF, and your timing, and your BRAF and a few others all control how rich it is.
    5BA8
    4,335
    Why are you starting a second thread for the same exact scenario? Stop it. Keep everything in this one thread.
    5BA8
    4,335
    Where is your current data log after having replaced the plugs????
    Nov 2023
    28
    log file after new plugs
    new log after changing plugs plz help why so rich
    5BA8
    4,335
    It's not rich, it's lean. It's adding a bunch of fuel via the trims.
    Bank 1 in worse than bank 2. Like you have injector oring vacuum leaks on that side or something like that.
    It's not running hot enough either. It never even got to 180 in that log. Take the 160 stat out and throw it in the trash and put a 185 in it.
    Nov 2023
    28
    ok thanks ill replace orings on injectors and put 185 stat in then log again . not sure about this but what if i put more fuel to it and try yes or no or even shut off fuel trims and no close loop operations like it was when i bought the car i went in and turned on fuel trims and made closed loop . i am running a 350turbo trans could this be a factor
    5BA8
    4,335
    What intake manifold is on the car?
    The trans has nothing to do with the split fuel trims. They are a result of something being different from one bank to another, vacuum leaks mostly, followed by weak cylinders, manifold design, exhaust leak at the head, etc.
    The injectors should fit tightly to the bores in the manifold. If you can slip them in and out easily you have the wrong size o-rings.
    Before you make any tuning adjustments you need to do your best to remedy the split fuel trims.
    Nov 2023
    28
    stock manifold they say it flows the best. im also curious when i bought this car why was trims disabled and had it set for no closed loop once i enabled these problem started im changing everything you said and intake gaskets also thanks and also injectors
    5BA8
    4,335
    Stock intake definitely should not have split fuel trims. That means something is mechanically wrong.
    No telling why it was tooned in open loop. A lot of idiots do that.
