Results 1 to 6 of 6
Thread: dakota digital speed sensor caliibration
    Jun 2021
    32
    I got a 1979 cutlass ls swap 5.3, I have a th350 trans with the Dakota digital sending until electrical speedometer and I've researched the hp tuner site and YouTube on how to calibrate my speedo. I got far as to putting in my numbers in the tire wizard on hp tuners and changed my speedo ratios. Now when I come to a stop, I have like a hunting idle. Any help would truly be appreciated.
    1,609
    A current version of your tune and a log of the problem is pretty much required every time. But making a new thread for every problem isn't. It would save you time explaining things to just add to your existing thread.
    Jun 2021
    32
    Ok, I didn't know, thanks
    Jun 2021
    32
    a current version of your tune and a log of the problem is pretty much required every time. But making a new thread for every problem isn't. It would save you time explaining things to just add to your existing thread.
    79 cutlass (My Tune) vss calibration.hpt
    drive after VSS calibration.hpl
    2,995
    It doesn't matter if the speedo is accurate in the scanner/ECM unless you are using that to drive a speedometer.
    Often the sending units for older trans/cable speedo VSS things.. they aren't the factory 40 pulse per rev. Check your install instructions for the sender. There is a spot in the tune for VSS pulse per rev.
    Tuner at PCMofnc.com
    Jun 2021
    32
    thanks for the information
