Results 1 to 7 of 7
Thread: 06 Sierra/Silverado P59 OS 12619623 Adding flex
    Tuner 01 MidMet WS6's Avatar
    Jun 2007
    St Paul, MN
    169
    I always seem to struggle with OS compatibility when it comes to P59 controllers. In this case I have am trying to add flex to an 06 Sierra that was a factory flex truck (virtual not a wired sensor). I have enabled flex in the tune and enabled codes P0178/P0179. The codes will not set with the sensor disconnected. To the best of my knowledge GM stopped using wired FF sensors in 2005 and I have been unable to find anything with OS 1269623 that I can use to segment swap the flex info into.
    I did try flashing an 05 Flex OS 12592618 into the PCM, that did not end well (engine hot message on the cluster and bricked the PCM). I know there are ppl out there that can build out what I need in used defined parameters but I have never understood or learned how to do that. If someone can help me out I would be willing to pay for the education, or just the service.
    Thanks in advance!
    Oh, I attached the tune file, this is still a stock/non segment swapped OS with a 4L60, no need for 4L80 changes on this unit
    TCPtuned 06 Sierra 5.3, 4L60, 2800rpm converter, large cam, headers, factory flex.hpt
    01 WS6-M6, PRC Stage 2.5 5.3's, MS4, Kooks 1 3/4", custom built full true duals w/ X-pipe, SLP lid, tuned via HPTuners
    Jun 2007
    St Paul, MN
    169
    Bumping this back up to the top, really hoping for some help.....please!
    Jun 2007
    St Paul, MN
    169
    One more run to the top anybody good with adding used defined to this tune for flex or have another work around?
    Jun 2007
    St Paul, MN
    169
    One more time to the top and I am going to start swapping OS's and maybe brick another ECU.
    405
    2,366
    Quote Originally Posted by 01 MidMet WS6 View Post
    Thanks in advance!
    I understand you are trying to add the physical sensor but why? If it already was a FF truck was the virtual flex not working? The problem is the earlier FF P59 trucks that used a sensor, those calibrations are not going to be compatible with the 06 ETC and TAC hardware. I know virtual flex doesn't always work but I've seen plenty that it works fine on.
    Jun 2007
    St Paul, MN
    169
    Virtual flex is wildly inconsistent with a cam/headers truck. Just more accurate to run a physical sensor.
    405
    2,366
    What inconsistencies are you seeing with known tested alcohol content?
