Results 1 to 16 of 16
Thread: 03 Silverado 1500hd 6.0 Mods Won't Now barely idles
    Apr 2024
    7
    Hey everyone, I'm new to the forum and really to modifying vehicles. I've always done all my own repairs without issues, but the last 2 weekends has me really stumped so I figured I'd hop on and ask the gurus to see if I'm even on the right track.
    The vehicle is a 2003 1500HD 6.0 LQ4 with return style fuel system. With the original intent of just changing the cam I ended up doing a bunch more. Here is everything I just did.
    BTR Truck Norris cam. New valve seals and springs.
    TBSS Intake with the 90mm TB-Gold blade using the Xlink 50lb injectors from Glenns
    1-3/4 Long tube headers full 3" to x pipe and 2 mufflers
    QFS 340LPH fuel pump
    C5 58psi reg/filter
    Initially I had the C5 reg/filter mounted next to the rail, but had concerns as any slight side load would cause it to leak on the output side. All I did to the stock tune was modify the Flow Rate vs KPA from 25 to 50lb injector, and it seemed to idle correctly with a little idle lope.
    Last weekend I moved the C5 reg/filter down to where the stock fuel filter was close to the tank. In doing this I switch to a 6AN version of the C5 reg. When I went to start it I noticed it didn't nearly as smooth at idle. I noticed the B2 O2 was .450mV constant so I changed out the O2 and now it is behaving like B1.
    Is it possible that locating it to the rear would cause the rail pressure to be that much lower? It's all 3/8 from the filter forward. I checked all the plugs and they were all darker brown, but on one side it was white like it was washed clean? I checked and made sure all the gaps were 0.045".
    I don't have my wideband installed yet. Now that it is relocated I'm getting P0300 periodically and noticed that knock is occuring.
    If anyone could give me a suggestion it would be much appreciated. The second one all I did different was change from 50lb/hr to 45lb/hr hoping to trick it to add more fuel.Stock20031500HD-45lbhr.hpt
    24-04-27 16-58-46.hpllatest.hpl
    Mar 2009
    Andover, MN
    538
    Looks like an exhaust leak on bank 1.
    What is
    Apr 2024
    7
    Sorry it was a package that included the tbss intake manifold with the fuel rails and
    GM/Delphi 50lb/hr at 58 psi Injectors (Part number 12613412).
    https://www.glennsautoperformance.co...ails-injectors
    I did heard a ticking noise on the drivers side only. I couldn't tell if it was internal or an exhaust leak. I'll check that in the morning.
    1,620
    Typically “return” style fuel system means vacuum regulated and c5 means constant pressure. Which are you trying to do?
    Apr 2024
    7
    I'm just trying to run the constant 58psi. I was just trying to describe the system since the 03 Silverado was a change over year where some had a 3/8 supply and 5/16 return line, and some only had the 3/8 supply midyear and all 04+. Since mine had the return I had to use the C5 regulator/filter
    SoCal
    1,642
    If it is a 412 GM injector then your data is wrong.
    Here is a non referenced to your data.
    You have a bit of tuning to do. You may want to start over with the correct injector data.
    Stock20031500HD-50lb_412.hpt
    Apr 2024
    7
    I spent a bunch of time and found my exhaust leaks (about 1/4" section of butt joint that I missed welding, and the gasket was also leaking). I got a smoke machine to be sure and kept at it until I didn't see any more leaks.
    I reverted to the stock tune with the injector data TheMechanic provided. B1 LTFT still goes up, so I'm not sure what I'm missing. I also swapped B1 and B2 o2 sensors just for a sanity check.
    Here is my latest log. Any advice on what I should try next?
    aftermanifoldleakfixedgasket.hpl2003HD 412inj.hpt
    Mar 2009
    Andover, MN
    538
    After driving it around the trims look like they are working. Right after startup there is something weird going on. It is triggering the knock sensors and driving the trims up. Can you hear it misfiring?
    Apr 2024
    7
    Yes at idle it sounds like it is misfiring pretty bad anything above that seems to be better. I've only drove it around my lot a little. Tomorrow I'm hooking the smoke machine up to the intake tract and looking for other issues. I picked up a fuel injection system diagnostics set and am going to look at the fuel pressure actually being seen at the rail. I swear it idled correctly when I had the fuel pressure regulator up by the intake. When I relocated it down to the frame rail I had to install new hose. Is it possible that debris from the cutting of the nylon hose could have caused an injector to clog and look similar?
    I will verify the fuel pressure tomorrow, and look for any intake tract leaks. I would have thought if it was an intake leak or fuel pressure that both banks would have had the ltft issues. I'm just a newbie trying to make sense of it all.
    Thanks again, I appreciate all the help
    Mar 2009
    Andover, MN
    538
    Id try to figure out what hole is missing. Temp gun at the manifold/header, kill a cylinder with VCM controls, or unplug a coil or injector one at time.
    Apr 2024
    7
    Sorry its been awhile, but I spent a few weeks trying to figure out why it was getting the misfire. It only does it at idle. I ended up replacing plugs again, MAF, and all coils and wires and had the same result. Got a fuel pressure gauge and put it on the rail and see a pretty constant 60psi at idle. I was able to get it to idle by changing the idle airflow required enough to start going through the MAF and VE tables. I did multiple drives on the MAF, and then 4 times on the VE tables. Probably about 200 miles worth of updating and trying to hit all of the points on the table. I need to go through once I get the wideband working. I apparently ordered the wrong one. I didn't realize the CAN only feature was 2008+ so I had to order a new harness.
    Can you guys take a look at the current tune and logs and see if I'm doing anything super obvious wrong? Seems to be running decently well. I'm still seeing the knock counts but it looks like it only does it around idle. I'm just happy the fuel trims are getting closer to zero.
    VE4Update.hptVE4.hpl
    Thanks in advance for any suggestions.
    Mar 2009
    Andover, MN
    538
    Make sure you are resetting your fuel trims after making corrections. VE is still needing a lot of work and your trims are pulling a lot of fuel yet. Is there exhaust rattling or a heat shield? You can desensitize the knock sensors at idle regions, but I would be looking for the mechanical culprit first.
    Apr 2024
    7
    I did forget to reset the fuel trims after making corrections a few times. I'll get under it and see if I can find something rattling. I keep getting random TPS sensor errors too. I'm using the XLink with the gold blade 90mm. I was thinking about using an adapter plate and trying the stock 78mm again to see if that goes away. I put in flexible exhaust couplers just after the headers as I wondered if it was too rigid and somehow translating those vibrations back in and being perceived as knock but apparently that was just a bad assumption as it is still doing it.
    I'll get under again and see if when it stumbles at low rpm if somehow one of the pipes is coming into contact with the frame. I know it was tight but I tried to maintain a 3/4 to 1" gap between all obstacles.
    Arizona
    559
    Quote Originally Posted by oldnoob View Post
    id ditch all that and put the stock t body and intake back on... it was a 3 bolt right, and youve know x linked a 4 bolt throttle body on it?
    Did you change the intake vlume/scaler or anything to the new TBSS intake?
    But really frot he msall gains, id put the stock intkae/tbody back on
    Sep 2021
    Kentucky
    569
    See if this gets you starting, idling, no flashing cel at idle. Make sure dfco is off while tuning ve and maf.
    Sep 2021
    Kentucky
    569
    Also, dont forget to make sure your map sensor data is correct. Nothing wrong with the intake choice but i always install the 4 to 3 bolt adapter and run the stock tb with the gen 4 intakes at my shop. If you already have the x link junk might as well run it.
