Results 1 to 7 of 7
Thread: Procharged 17 Challenger HP70 3600 CD WOT 2>3 shift issue
    Nov 2021
    23
    Well after reading up and seeing many issues with the Circle D 3600 stall on the RT challengers I thought I would throw out my issue and hope for an easy fix from people smarter than me! Little background just trying to get in the 10's with my procharged 17 RT. Running a 392 intake & 3.09 diff with Texas Speed stage 3 cam and Circle D 3600 Stall Converter. Attached are track logs a 11.39 and 11.46 and my current tune. You will see in the log the first initial peak has to be my Stall please let me know if I am wrong but biggest issue is the 2>3 shift commanded 20+ MPH before it shifts. There is no dip at 4800 so I know there is an issue with SRV actuating so I have already ordered a Z automotive SRV controller just not here yet. Could increase shift pressure but that first peak really throws me off. Any help or thoughts would be greatly appreciated.
    -Dogg
    Aug 2021
    Indianapolis Area
    187
    Quote Originally Posted by themikecooper View Post
    -Dogg
    Hello,
    Looking at the logs (both have a very very similar behavior):
    - Uneven shift schedule
    - Shift pressure not ideal
    - Flare 4th to 5th
    - Weird behavior on torque (could be related to timing / VE table / torque management)
    - Potential lack of pressure on torque converter
    - Torque management
    DodgeBoy.
    YouTube: https://www.youtube.com/@dodgeboy2785
    Nov 2021
    23
    Quote Originally Posted by DodgeBoy_8HP View Post
    Hello,
    - Flare 4th to 5th
    - Torque management
    DodgeBoy.
    I have been running in sport mode I wonder if switching over to track mode would automatically up the shift pressure.
    - Uneven shift schedule - Adjustments to shift schedule was to hook better and attempt to finish 1/4 without 4>5 shift.
    - Shift pressure not ideal - track mode switch potentially.
    - Flare 4th to 5th - wondering if needed for 1/4 mile I feel like 125 mph in 4th is archivable.
    - Weird behavior on torque (could be related to timing / VE table / torque management) - Did notice VE is missing smoothing in WOT.
    - Potential lack of pressure on torque converter - Is that a Circle D 3600 issue or in tune.
    - Torque management - Clearly an issue.
    -Dogg
    Aug 2021
    Indianapolis Area
    187
    --> Understood. It is still possible to make it more even.
    --> Yes, track mode would change shift pressure
    --> It might be possible in case shift points are higher (different CAM would help)
    --> Sounds good
    --> Tune (apparently)
    --> Yes. Torque behavior is very strange
    Thanks.
    DodgeBoy.
    Nov 2021
    23
    --> Sounds good
    Thanks.
    DodgeBoy.
    I appreciate your responses and think I have a plan switch to track mode and adjust the shift schedule for 1/4 mile focus. I also need to blend the VE tables with more WOT cells. After making adjustments I will post the tune.
    -Dogg
    Jan 2022
    923
    the tc behavior is not strange...
    the throttle is closing and making it look strange
    *never tune engine and trans separately
    Nov 2021
    23
    They were originally tuned together but when the procharger was added they were split in two different files or so I thought please look at the attached file2017 Dodge Challenger_FIC1000_2.5_Pulley.hpt
    -Dogg
