Results 1 to 5 of 5
Thread: More hiss L5p
    Jan 2016
    East Bend NC
    129
    More hiss L5p
    What table do i adjust to get more hiss from my 2018 L5p? It has none at the moment and the rumble drone drives me nuts. Been straight piped.
    I haven't done an L5P but should be your vane table at idle, close em up. My LMM sits at 80% closed at idle. Run it up to 95% or more and she'll whistle pretty good with that pipe
    2006 GTO 403ci lsa heads kooks long tubes corsa ss exhaust OTR intake HPTuned
    2010 GMC Sierra LMM Duramax. Exhaust and tuned
    Jan 2016
    East Bend NC
    129
    Quote Originally Posted by Stroked06Goat View Post
    Thank you when I get home tonight I will look at the tune and see what I come up with
    Advanced Tuner projectlnf's Avatar
    Jun 2012
    warrenton va
    477
    Quote Originally Posted by Rick P View Post
    Vane position down at idle set it to 90% or more.
    Try to blend the vane position from idle up and over if not the vane position with be erratic when you press the pedal down.
    You want it to be closed at idle and then slowly open when you press the pedal/build boost.
    2003 Ford excursion 6.0 PSD
    No limit intake
    Straight pipe
    Studded
    EGR delete
    KC billet single plane compressor wheel
    Self Tuned
    XDP Regulated return
    RDP Fuel sump
    AEM progressive water meth
    Custom suspension air bags
    8" lift
    35" tires
    Jan 2016
    East Bend NC
    129
    Thank you
