Results 1 to 5 of 5
Thread: e38 ecm code p0606 - clears and comes back
    Jan 2022
    6
    Hey everyone,
    I have a L92 from a 2008 escalade in my 96 LX450 (Landcruiser) with a manual trans and a cts-v pedal. I have never touched the throttle tables.
    I have been getting the code "P0606 ECM/PCM Processor" every 2-3 start ups, it started happening about 2 weeks ago. It will start and idle with a dead throttle. I can clear the code and drive normally with no issue. The first time it happened I was in the desert 150 miles from home and got back no problem.
    I have had this setup for 2+ years and over 12k miles with no issues. I have checked all grounds and wires and everything looks good.
    Could it be the ECM is dying?
    Is there anything else I should check?
    If I replace the ECM and I am unable to do the crank re-learn process because of the manual trans will it run and drive normally?
    Thanks!
    -Justin
    5BA8
    3,648
    Throttle body/PCM/pedal have to match.
    Edit: wrong section BTW.
    email=[email protected]
    Jan 2022
    6
    Then why would work with no issue for 2+ years? CTS-v in a swap is common with no issue.
    Anyone have constructive input?
    405
    2,384
    If it still runs fine with the code set then set the code to NER. I had to do that on a 08 Escalade a few years ago and never heard back from the customer.
    Jan 2022
    6
    Figured it out! The nut holding the main ECU power cable to the lug on the power distribution block was slightly loose. Tightened it up and it's good to go.
