Results 1 to 15 of 15
Thread: Checksum error med 9.1
    Jan 2022
    20
    Checksum error med 9.1 after running
    hello, I'm having a problem with my tune, audi a3 tfsi 2.0 2008 manual, I did a tune in this car and it worked perfect without errors and without codes, but after driving just over 100 kilometers the car goes into emergency mode and generates an error of checksum p0601 and it stays like that until I record another tune, then it unlocks and works, I changed a torque monitoring table, is that what is causing it?
    Jan 2022
    17
    http://wiki.ross-tech.com/wiki/index...5/P0601/001537
    Have you tried going back to stock and seeing if it happens?
    Jan 2022
    20
    I haven't tried it, when it was original there were no problems
    Jan 2022
    17
    If it was me that would be the next thing I would test. Otherwise you can try to reach out to support and see if they can assist.
    Jan 2022
    20
    Lightbulb
    Quote Originally Posted by TWiST View Post
    the car is running now with the tune i made. I had changed torque monitoring tables, I removed that and also a change in the idle and I didn't get this error anymore, let's see if it comes back or not. the owner has had the car for three days, so far no errors....
    Jan 2022
    20
    now after 8 days, the car has an epc again and went into emergency, i suspect the same problem with checksum p601, but this time only epc on, the injection fault light does not, and the car lost turbo pressure before turn on epc
    Jun 2023
    Hi Fnetotuner, I am also currently having the same issue on my 2008 skoda Octavia mk2 vrs with a med9.1 ecu and ea133 motor seems to happen after around 150km of driving without an ignition cycle it has been an issue since flacing my ecu. I have reverted back to the stock tune didn't fix it, re wrote my map after finding it was missing parameters that the stock tune had. Still no luck also talked to the support line who told me to disable the fault code you get the same issue but without a fault code i feel it may be an issue with the software but need to talk with hp tuners support about the issue its a real pain in the ass as i need to bring a computer and my mates dongle with me when i drive and constantly reflash the car.
    Tuner SuperG5's Avatar
    May 2021
    Mars
    50
    What's your file look like? 👀
    Quote Originally Posted by BigShack View Post
    Is it possible to see your tune file vs stock file? I had a similar issue and just updated all aircharge conversion tables . I always had epc above 50% engine load . I believe the ecu sees not enough boost the same as too much boost. As weird as it sounds . It may be to prevent high turbine rpm from a boost leak . But idk 🤷🏼*♂️ just a thought .
    Jan 2022
    20
    hi, im aparently solved the problem, the problem is turned off TEST OF O2 on engines diag, exhaust,i turn ON same as stock and the car runs fine, no codes. delete only DTC page in this ecu. use the beta new software for back to stock.
    Jan 2022
    20
    Quote Originally Posted by SuperG5 View Post
    Is it possible to see your tune file vs stock file? I had a similar issue and just updated all aircharge conversion tables . I always had epc above 50% engine load . I believe the ecu sees not enough boost the same as too much boost. As weird as it sounds . It may be to prevent high turbine rpm from a boost leak . But idk ����*♂️ just a thought .
    here the car runs fine,1,35 bar peak and tapering 0,9 here the files.a3 sportback 2008 kpn v3Last stage2 1,4.hpta3 sportback 2008 kpn STOCK.hpt
    no knock and no epc register.
    Jan 2022
    20
    The error already persist here after driving more 100-150 km, hptuners suport team they don't do anything. The problem is hptuners software?.. no tune cars with med 9.1 with hptuners
    May 2017
    texas
    89
    Quote Originally Posted by Fnetotuner View Post
    did you ever find a solution? i am dealing with the same thing, p0601 and epc errors with running rough. reflashed the ecu to stock and its good to go for now but i know it will happen again.
    I am unsure if i should buy vagcom and update ecu to latest revision, or buy an entire new ecu? Its possible its damaged due to the code i presume and will continue to cause this error after long drives.
    I dont want to be stranded 4 hours away from home without my laptop again.
    Jan 2022
    20
    Quote Originally Posted by melition View Post
    No solution, and the suport hpt is horrible and no have idea for help ou adjust checksum! @hptuners ??????? No support
    I back to stock with autotuner and the car runs fine, but when i writing my tune with hpt the car have a p0601 and epc and checksum error
    Oct 2023
    Russia
    5
    I faced this problem twice. the solution was the only one - I convert .HPT to a .bin file and upload it with another bootloader that fixes the checksum. Support said to upgrade VCM to the latest version, but nothing has changed. I think no one will pick our med9
    Jan 2022
    20
    How convert ??? And how bootloader do you use ?? Works with a kess ?
