Results 1 to 7 of 7
Thread: ecm lambdapro
    Sep 2021
    499
    ecm lambdapro
    Does anyone have the formula to get the lambdapro to data log in lambda? This one has a range of .55-1.75L.
    Tuning Addict
    6,876
    Fwiw 0v=.55 and 5v=1.75 lambda. It's also 8 to 25.5 afr. I thought I had the transform written down, but that's all I could find in my owner's manual.
    I would be willing to bet that Banish could tell you the offset formula. I don't remember but he may even do a walk through using it in his older vid???
    1,558
    Is this not just a simple linear mx+b calculation?
    Lambda=.24v+.55
    2,922
    IF you search by my name I have an excel sheet posted in here to figure this out for you.
    Tuner at PCMofnc.com
    Sep 2021
    499
    I contacted ECM and was given the same formula with the slope .24. It took me a moment to figure out but you use the inverse of the slope, 1/.24. The same slope if you swap the x and y. My bad for not realizing this is 7th grade math.
    Tuning Addict
    6,876
    Sorry I didn't still have the formula for mine and couldn't help, but you got her done I lost mine nearly 8 years ago when hpt did one of its crashes and I lost all of my math parameters. I had also switched to using cheaper AEM's by then and now I just require customers to have them installed instead of me having to worry about it, so mine's been in the case for a long time now. Just went through the crash bs again a month ago. Wonderful hpt.... At least ECM was able to get you the numbers you needed.
    ~Greg Huggins~
    Sep 2021
    499
    I keep all my files including math on several flash drives. Hopefully this forum helps the next guy.
