Results 1 to 14 of 14
Thread: My Camaro now has Auto Stop
    Potential Tuner Psmith1024's Avatar
    Jul 2023
    9
    I've run into a little issue after getting my 2020 Camaro SS (manual transmission) back from the tuner. Twice now, the car shut off at a stop and I get an auto stop message on the dash. The tuner can't seem to figure out why either. How can this even happen? Camaros don't have this feature.
    I took it to have Kooks headers and BTR 220 camshaft installed. Then dyno tuned.
    Thanks in advance.
    Tuning Addict
    6,873
    LOL.... Cool. Are you sure it's auto stop and not just dying then showing the message? Post a log and the tune. Make sure 0 pedal torque, ignition timing and engine torque along with anything auto stop related is in the channels.
    ~Greg Huggins~
    Jul 2023
    9
    I would post a log, but unfortunately I opted for the TDN option this time around and can't see any of the tune info. Kinda regretting that decision.
    Tuning Addict
    6,873
    On the 20's the engine should read out if you get your own interface. If you have an interface in general you should be able to read it out depending on the software version and by that I'm referring to some of the newer software requiring a newer interface to read it. Otherwise, since they tuned it, see if they can figure it out and fix it because we can't do anything other than guess.
    ~Greg Huggins~
    1,554
    Does the car restart when you take your foot off of the brake pedal?
    Arizona
    268
    Strange. Try switching to sport mode. Sport mode is suppose to disable the auto/stop feature. So, it shouldn't shut off while in sport mode. This really sounds like the idle in the tune needs work. Again, this is just my opinion.
    2009.5 PBM G8 GXP M6 W/Roof-Self tune, OBX LTs, Kooks axleback, LSA blower, cam,
    Monster LT1-SC clutch, flex fuel, 12 psi [email protected] 1,800 D.A
    2007 TBSS-Self tune, bolt ons [email protected], 1,900 D.A
    1991 GMC Syclone- Self tune/catback 12.8@104, 4,200ft D.A
    Jul 2023
    9
    Negative. I have to turn the car off to restart it.
    Jul 2023
    9
    That did cross my mind this morning. I will try that when I drive the car home.
    But, yeah, I agree with the idle tune needing adjustment as well.
    1,554
    Quote Originally Posted by Psmith1024 View Post
    Doesn't sound like it's actually autostop mode in what I think of as autostop (shutting off at redlights). Maybe just something in a left over piece of code that happens to pop up on an unexpected engine shut off.
    Arizona
    268
    I haven't had stalling issues with GEN Vs in some time, but if I recall correctly and if the car does end up stalling, it will say something like "auto shutoff" in the DIC. Reminds me of the Hellcats when you go to start the car, and the DIC tells you to step on the clutch and brake to start the vehicle, when the vehicle is an automatic. lol
    Jul 2023
    9
    A little update from my tuner. He confessed that the torque management is rather intrusive, for lack of a better term. He claims that the torque management will pull timing if it thinks it's making too much torque. Predicted vs actual. And that the second that I let out of the gas, TM pulls all the timing away, stalling the engine.
    Conversely, when adjustments are made one spectrum, there is an opposite effect elsewhere in drivability. WOT it wants to yank timing too.
    Sorry, still no data log files. This is about all I got.
    Is this indicative of 2020 models and up? If he's lost, I ain't got a clue.
    Arizona
    268
    He needs to reduce torque in the idle areas within the torque model.
    Jul 2023
    9
    Alright. I will relay that message.
    I'm so close to just breaking down and just buying a MPVI3 and buying credits. That way I can see what's going on myself.
    Arizona
    268
    If you're pretty serious, its great to have your own interface as well.
