Results 1 to 3 of 3
Thread: Idle issues suggestions
    Dec 2023
    9
    BaseTuneWith180.hpt05022024pulls.hpl
    Hey guys!
    I have issues with my idle. After driving the car for a bit when I stop my car at a light and put the car in neutral (6 speed car) my car oscelates between 500 rpm and 2000 rpm depending on the weather. Sometimes, the car will drop so low in RPMs that it will stall. This has been an issue since I got the car tuned. I was wondering if you all can look at my settings and see if there is something obvious with my tune that would correct this problem. Current specs on car are below. If someone would like me to run a log with something specific let me know. The attached log isn't the greatest to display this but I thought I would ask first. Thanks in advance!
    Car has a 426 stroker with a whipple with a 3.25 pulley. 85lb injectors and an unknown fuel pump and cam.
    Thanks!
    Dec 2023
    9
    Also, if I were to guess I would say the PID is fueling too much to correct the issue. I'm kinda new at this so bare with me. My knowledge is reading stuff online and reading books pretty much. I'm not sure exactly where to look in the software.
    5BA8
    3,604
    85 lbs. injectors from who? Do you have the data sheet in your format?
    email=[email protected]
