Thread: Supercharger LS
    Jan 2024
    colorado
    Supercharger LS
    Hello,
    We've been having drivability issues with a supercharged. It has a Magnuson blower, 3.2 pully and 17113739 injectors. Initially the fuel pressure was set at 38lbs. O2s don't read while logging would like a second set of eyes on the file.
    Thank you.
    1970 ElCo
    Jul 2012
    Florida
    1,498
    Do you have a log?
    What is it doing? Fuel pressure should be at 58# for those 42# injectors. Then you will need to re visit the IFR, and probably retune MAF and VE table.
    2013 Silverado 5.3, 6L80k 8.8
    Jan 2024
    colorado
    Yes I have a log from before I raised it and one after.elco psi58.hplelco 36 lbs fuel.hpl
    3,015
    In both of those logs the o2's and fuel trims were working correctly
    Tuner at PCMofnc.com
