Supercharging a 2022 Mach1
Hello Guys,
Im used to tune some LS Camaros (NA cars), with HPTuners.
This is the first time on stangs, but with a SC kit from ESS. I already tuned some german cars with Bosch MG1 ECUs, all of them turbocharged ones, but not with HPTuners.
Im a little bit lost on how the car will see the boost (9 psi kit). I tried to modify the load axis from some tables, is that right ? Put some max map delta higher and so on.
coyote gen3 sc tune v1.hpt
Any thoughts on that ?
Hit me up if you need a base tune. This is the best way to learn and start working on those cars.
